It is currently Fri Jun 27, 2025 9:26 am
 Post subject: Engine number
PostPosted: Wed Jun 09, 2004 12:28 pm
Can anyone tell me the what this engine is out of ?
Is it a normal 1275 or something more ?
12YDTaH7022.
76 1275 Leyland S
PostPosted: Wed Jun 09, 2004 12:43 pm
12YD/Ta/H 1275 ? Leyland 1275LS (12" Wheels)
http://www.hotbricks.org.au/files/engine.txt
Matt
PostPosted: Fri Jun 11, 2004 3:05 pm
Leyland 1275 LS start with 12H902.. That hotbricks site is wrong!
This engine number equates to a Morris 1100S
Morris 1100S actually had a 1275 engine from the factory. Even though the name still has 1100 in it.
Some Morris 1100S even have the same small journal crank and rods as a Cooper S! But they still have the solid block with no cam follower covers on the back.
Brett Nicholson
Greendale (near Ballan) VIC.
1971 Morris Mini Moke
1966 Austin Mini
1965 Morris Mini Traveller
1973 LR Series 3 88
2007 LR Freelander 2
PostPosted: Fri Jun 11, 2004 3:09 pm
Bugger... sorry 'bout that
PostPosted: Fri Jun 11, 2004 7:05 pm
Yep, BNicho is right. Morris 1100S. I run one in my car.
They have a small journal crank, it's cross drilled but is EN16 steel (not EN40B like an S) and use S rods.
I run an S crank in mine. Just had to play about with thrust washer thickness, otherwise it drops straight in.:P
 Post subject: Not to mention the head!
PostPosted: Fri Jun 11, 2004 10:01 pm
8) probably also has a 12G940 "big valve" head - take off the rocker cover and check for the cast in number between the rockers..... :P
PostPosted: Fri Jun 11, 2004 10:33 pm
Stock head on 1100S was a 12G940, with 33mm/29mm valves. Some heads had 12G938 stamped next to the thermostat (where most MK2 Ss had 12G1805 stamped).
Basic casting was the same for both, but the Cooper S had 35.6 intake valves.
Mine now has 35.6/31 valves...and BIG ports.. :wink:
