It is currently Fri Jun 27, 2025 8:52 pm
Post new topic Reply to topic  [ 34 posts ]  Go to page Previous  1, 2, 3
PostPosted: Sat Mar 26, 2005 6:27 pm
Check the shaft, bush & needle bearing are OK. Buy a kit if they are stuffed.
Outer bush needs reaming in line, after fitting. Most Mini places can do it for you. :wink:
<edit> also check out the knuckle joint cup. Good time to fit a new one, but do the other side too or car will lean... :lol:
PostPosted: Mon Mar 28, 2005 11:44 am
I'm thinking I might as well put hi-los on the rear and replace the completely whacked shockies on all 4 corners. The rubber cones look reasonable. I probably should do new knuckle joints as well yeah?
If I was going to go all out I think I'd get Koni shocks but I think they're just too expeno. What is a good 'middle of the road' shock absorber?
dewey
dwightgunning.com
PostPosted: Mon Mar 28, 2005 9:19 pm
Jeff has a couple of trailing swing arms. Is there any difference between hydro and dry?
dwightgunning.com
PostPosted: Mon Mar 28, 2005 10:26 pm
Yes. Don't swap them, geometry is quite different.
Hydro ones have brake pipe at bottom, not top. :wink:
