It is currently Sat Jun 28, 2025 6:07 am
 Post subject: Driving Lamps
PostPosted: Thu Mar 24, 2005 6:45 pm
Decided to run 4 driving lamps instead of 2 driving lamps and 2 fog lamps.
I have been able to collect 4 hella 6 inch lamps which have different watt globes 100 watt x2 and 55 watt x2.
My question is what wattage globes should l run 55 or 100 ? l feel 50 watt is sufficient
l am using a nissan pulsar alternator and the lights will be working through relays
 Post subject: Re: Driving Lamps
PostPosted: Thu Mar 24, 2005 7:27 pm
Add up all the power being consumed in watts, divide by 12 and you have an answer in amps. Does this exceed the alternators capacity? I think it would go close. If it does not you can use the present globes and if it does you will have to put replace the 100's with 55's. Personally I wouldn't use less than 100's, I would find a bigger alternator. The reason for that is I am an old fart and us oldies lose the ability to absorb light by a huge amount. In other words we need brighter lights than you youngsters. Bugger the oncoming traffic. :D
Chris
Everything I like is either
PostPosted: Thu Mar 24, 2005 10:38 pm
Clean your windscrean also Chris :lol:
I would also use 100 just make sure they are postioned correctly.
You use to be able to get Aircraft Landing lights..Where are they now :wink:
PostPosted: Thu Mar 24, 2005 11:46 pm
I'd go 100's as well - up the alternator to cope.
I will be getting a combo of 2 driving lights for a nice wide spread of light at short range [> 100m] and a pair of pencil spots to fire straight up the road for a couple of K's
Don't forget to allow for the elecie requirements of the rest of the vehicle when working out your amperage - [sound systems can be quite a drain as well]
Cheers Dat
PostPosted: Fri Mar 25, 2005 9:02 am
The nissan alternator kicks out 70 amps ,so l will try the 100 watt globes. Using the table conversion the alternator can handle it . As l have owned minis off and on since the early 70s Chris has a good point about the need for increased light as l am no spring chicken myself.
cheers chasg
PostPosted: Fri Mar 25, 2005 6:09 pm
will a standard clubman alternator cope with a couple of 55w driving lights?
PostPosted: Fri Mar 25, 2005 6:31 pm
Yes, no problem. 8)
PostPosted: Sun Apr 10, 2005 5:47 pm
Chris what bracket/brackets are you using to mount your lights? Apparently there is a four light bracket that fits and bolts in behind the grill so you dont have to screw the lights into the bumper or the body itself but I havent seen on yet. What are you using..?
PostPosted: Sun Apr 10, 2005 7:07 pm
I haven't even begun to build my van yet. I will build a bar behind the grill with Tabs going through it I hope. Mount it as stiffly as possible using heavy material. Vibration kills globes and is very annoying. In my case no standard bar would be of any use as I am going to mount two Super oscars and two Hella 1357's on it all of which are 7'. I haven't measured the space between the headlights so I hope there is enough.
Chris
PostPosted: Mon Apr 11, 2005 9:57 pm
Installed the 4 driving lights on the weekend.
Used a dual light relay. Wired the 2 outer lights to one relay and the inner 2 to the other relay. Lights are activated from the high beam switch which inturn is run off a dual relay for the normal high/low beam.
Wired it this way because if at a later date l decide to run 2 fog lights and 2 driving lights
l only have to disconnect the high beam activation wire from the relay that is to run the fog lights and put in a manual live switch instead.
PostPosted: Mon Apr 11, 2005 11:14 pm
In NSW the lights have to switch off when the headlights are dipped. They also have to be able to be switched off entirely. I wire them with a two way switch so I can turn the headlights off when aiming them and then turn the driving lights on. It just needs another wire across the switchfrom a power source.
Chris
