It is currently Sat Jun 28, 2025 2:03 pm
 Post subject: needle selection?
PostPosted: Thu Mar 24, 2005 11:16 pm
does ausmini have a resident su guru?
i have my car all back together now after the work was all done to it.
i now have an unleaded 940 head with 1.4" inlets a shave and a little bit of porting and an re13 cam now.
the engine is a 1275 + 30 though (i thought they only went in 20 40 or 60 though increments so what would + 30 make it?)
still has extractors and electronic ignition as previous
unforrtunatly i don't have the cash on hand to get my proposed carby, a 1.75" just at the moment. so in the meantime i would like to set up my 1.5" to run safely on the new setup.
winSU won't give me a suggestion for my 1.5" as it recomends i be running a 1.75" so can anybody here tell me that needle i should be using at least in the interim till i can afford my 1.75" su?
cheers steve
Cheers Steve.
1973 south african mk3, 1275 +30 (1300), RE13 cam, hif44, mildy worked head with s sized valves, pulsar dizzy, 1.5:1 minispares forged rockers.
PostPosted: Thu Mar 24, 2005 11:25 pm
My best and Normal reaction is for you to contact Bill Silertsen (silvo i Thinki'll check) @ Midel Lakemba NSW 02/9759 5598 Will listen and talk to you.
I'm Guessing you have not had it dyno'd recently or prior :?
PostPosted: Thu Mar 24, 2005 11:35 pm
no need to prior
but will definatly be happening after i switch to the 1.75"su
all i am after at the moment is to not melt the pistons down basically
cheers steve
Cheers Steve.
PostPosted: Thu Mar 24, 2005 11:37 pm
steveandsash wrote:
no need to prior
cheers steve
He'll get you on the green 8)
PostPosted: Fri Mar 25, 2005 6:02 am
A +.030" rebore gives 1300cc, these pistons were popular for racing in 1300cc class. (call them 1299.... :wink: )
