clubman77 wrote:
I was looking at the megasquirt ECU's as well.
There is a newer version called DIY PNP more info can be found here:
http://www.diyautotune.com/diypnp/index.htmlThe 72pin version allows the standard starlet loom to plug directly in the ECU.
Also this version has been modified to work with the starlets ESA ignition.
That looks very handy, have to check if i kept that part of the loom though, and im quite keen on mappable ignition too.
clubman77 wrote:
Thats all the information I really know. I want to get my mini(4efte) on the road before I start playing with an aftermarket ECU.
Im starting to regret getting rid of my ecu, a piggy back would be so much easier and cheaper.
Btw where in brissy are you?
