It is currently Tue Jun 24, 2025 12:15 pm
Post new topic Reply to topic  [ 18 posts ]  Go to page Previous  1, 2
PostPosted: Wed Apr 21, 2010 9:13 pm
Mearcat wrote:
92 wrote:
A 4age gearbox is the same size a 4efte box, both C series toyota transaxles. Just the bell housing and ratios are different.
So it's the engine that causes the track increase then, not the gearbox?
A 4age is about 50 or so mm longer than a 4efte and can be fitted to a normal track car as per the links.
The equal drive shaft extensions some people are using (myself included) come from a 4age 20v engine and gearbox and these run standard mini track.
4efte powered Clubman
supercharged 998 race car
PostPosted: Wed Apr 21, 2010 10:33 pm
cazmo wrote:
you don't need to increase the track.
Check the links in my post above
Yeah I saw those and understand that the standard track doesn't need to be increased. I was just trying to figure out why the track of the Rich's white 4AGE Mini is so wide (about 4-5 inches either side)
-Alan
PostPosted: Wed Apr 21, 2010 11:48 pm
probably just makes it easier - like extending the front, could be done without stretching, but harder...
