It is currently Tue Jun 24, 2025 4:44 pm
PostPosted: Mon Apr 12, 2010 1:52 pm
hey engine converters....i was just wondering, i had a quick look but couldnt seem to see anything, would the twin cam 1.6L fuel injected motor from the 87 Hatch back fit in a mini. Not sure the name of the engine?
PostPosted: Mon Apr 12, 2010 2:20 pm
4age, theres a clubby down south that has the conversion done i think (extended the front if i remember correctly?) but for 86kw (claimed) at the engine why not just go a 4efte and have a hell of a lot more fun?
PostPosted: Mon Apr 12, 2010 3:32 pm
4AGE come in 86kw, 88kw, 100kw, 20 valve and supercharged variants. There is a lot more scope for bolt-on mods with the 4AGE family than the 4EFTE.
The problem is the gearbox on them is just huge, which is the main stumbling block. The Starlet box is much smaller.
There is a car in Perth running a later twin cam 20V, but it was built in the UK and imported later. Not sure you could build it here and get it registered as the track has been majorly widened.
The Sydney car had a 4AGE engine adapted to fit a normal Mini gearbox and I'm pretty sure it was a dedicated track car.
Brett Nicholson
Greendale (near Ballan) VIC.
1971 Morris Mini Moke
1966 Austin Mini
1965 Morris Mini Traveller
1973 LR Series 3 88
2007 LR Freelander 2
PostPosted: Mon Apr 12, 2010 3:46 pm
The only one I know of here is Warwick Agustin's sports sedan Mini, it has a 4AGE, chain driving into a Mini box.
It's been running for years, doesn't seem to be too unreliable.
PostPosted: Mon Apr 12, 2010 4:14 pm
Rich's car is awesome! His username is 4agecooper on here.
PostPosted: Mon Apr 12, 2010 4:37 pm
Late last year, I was talking to a guy at the Dept of Transport about approval for my 4EFTE conversion and we got talking about Rich's car here in Perth. The guy said that it was "touch and go" to whether they would allow it to be regsitered due to the massive increase in track (due to the big gearbox). It was allowed mainly because it was an import but was told they would never allow one to be built like that locally. NSW may have similar laws about not widening the track too much, let alone ~5 inches!
-Alan
PostPosted: Sun Apr 18, 2010 2:22 pm
check out these mate. both have standard mini track.
4age 16v http://www.16vminiclub.com/forums/showt ... hp?t=20788
4age 20v http://www.16vminiclub.com/forums/showthread.php?t=8510
I think the best part about a 4age is that you can put a turbo on it and still be legal.
72 Clubbie - Current project - Vauxhall C20XE 2000cc 16v 150hp.
78 Clubbie - Future project.
PostPosted: Sun Apr 18, 2010 7:30 pm
thanks mate
PostPosted: Mon Apr 19, 2010 7:45 pm
A 4age gearbox is the same size a 4efte box, both C series toyota transaxles. Just the bell housing and ratios are different.
4efte powered Clubman
supercharged 998 race car
PostPosted: Mon Apr 19, 2010 9:59 pm
Are you certain? The Corolla box looked much bigger to me, and I was told on Toymods the two do not interchange. :?:
Brett Nicholson
1966 Austin Mini
1973 LR Series 3 88
PostPosted: Mon Apr 19, 2010 10:04 pm
Its the bellhousing that makes them non-interchangeable. Do we know if the bell housings can be swapped?
Simplify and add lightness
PostPosted: Mon Apr 19, 2010 10:58 pm
yes, bell housings can be changed.
you just need to use the bell housing that come with the engine.
so you can use the 4age and 4age bell housing with a starlet box or a 4efte engine and bell housing with a corolla box i you feel like it.
PostPosted: Tue Apr 20, 2010 9:19 am
Damn, wish I hadn't sold my Corolla autox car now. If I thought I had a snowball's chance of fitting the driveline into a Mini, I would have kept it. The damn thing had 180,000km and went beautifully. :(
Brett Nicholson
1966 Austin Mini
1973 LR Series 3 88
PostPosted: Wed Apr 21, 2010 5:53 pm
So it's the engine that causes the track increase then, not the gearbox?
-Alan
PostPosted: Wed Apr 21, 2010 8:14 pm
you don't need to increase the track.
Check the links in my post above
