It is currently Sat Jun 28, 2025 6:23 pm
PostPosted: Mon Mar 21, 2005 7:25 pm
The best way to make sure the two gaskets and the C Seals are correctly fitted seems to be to carefully lower the gearbox onto an inverted motor (even the Doc agrees!). :?: :?: :?: :?
The best way IF you have a nice clean Box to mate to the engine...if it is a used one and you onvert it without cleaning first then you risk getting old oil and crud all over your nice new engine and gaskets....
PostPosted: Mon Mar 21, 2005 7:39 pm
Last long one one I did, I slung it evenly on a hoist. Used superglue to hold the 2 gasket strips on the block, and Loctite 515 on the rubber 1/2 moon seal to the motor.
No problem. :wink:
Another way is turn the whole thing upside down on a couple of old mattresses, then brace it somehow (steel fence posts?) to keep it steady while you drop the box on.
PostPosted: Mon Mar 21, 2005 8:48 pm
"steel fence posts?"
And Makka calles ME agriultural !
J
PostPosted: Mon Mar 21, 2005 9:02 pm
Wouldn't an engine stand be a better bet?
They can be had fairly cheaply at Supercheap and the like on special.
I made a little mod to mine recently. Got an old alternator mounting plate at a garage sale (thanks Kazjim!) and welded a length of pipe (Scrap from work) to it to suit the diameter of the engine stand. Then drilled a few holes for the safety pin and voila.
I was worried if the two bolts would be enough, but Mini World had an article on engine build-ups recently and that's what they had. It's also in Vizards book (Admittedly they only showed the engine block not the whole motor on the stand).
KB
PostPosted: Mon Mar 21, 2005 9:21 pm
Yeah I've seen A series motors mounted by the alternator bolts, hey those bosses on the block are not real strong... I'd be wary of doing it with a gearbox on too. Maybe brace it to the oil filter mount, that's a lot stronger. :wink:
kazjim- you'd be amazed what I can make from steel fence posts, or angle iron, or water pipe... hey I grew up on a farm.. had a welder when I was 16! :lol:
PostPosted: Tue Mar 22, 2005 10:52 am
where would you normally hold a mini engine on an engine stand with the gearbox on?
Expert in training
