It is currently Sun Jun 22, 2025 5:22 am
Post new topic Reply to topic  [ 58 posts ]  Go to page Previous  1, 2, 3, 4  Next
PostPosted: Sun Mar 29, 2009 3:35 pm
MINImal effort wrote:
funnily stumbled across this the other day...
no idea how they compare ....
http://www.sdminis.co.uk/7.html
fair cost in those puppies!
would be a good price if we lived in UK, but not living here... they earn the same amount over there in pounds as we earn in dollars
PostPosted: Sun Mar 29, 2009 7:16 pm
I can see why the ones I have sold have gone to the UK now :)
4efte powered Clubman
supercharged 998 race car
PostPosted: Tue Mar 31, 2009 10:11 am
what's the going rate for the Mondeo EDIS system?
I got quoted $150 for the EDIS module, VR sensor and coil pack - good, bad, indifferent?
no pick-a-parts around here :(
EDIT:
local ford wrecker has a Mondeo in the yard, he doesn't know what all the bits are ("say that again", "what does that do?", "where is it?")
anyone got a photo of the mondeo bits?
PostPosted: Tue Mar 31, 2009 3:31 pm
forgot about this thread from aaages ago
http://www.ausmini.com/forums/viewtopic.php?t=11229&postdays=0&postorder=asc&highlight=edis&start=0
PostPosted: Tue Mar 31, 2009 4:03 pm
The trigger wheels wouldn't be too dear to laser cut from plate. I just got 20 turbo flanges cut for Benjamin so he can do his T25 kits.. 8)
PostPosted: Tue Mar 31, 2009 4:07 pm
yeah, I got a quote last week... about $30, then a little bit of machining
PostPosted: Tue Mar 31, 2009 6:30 pm
Depends on what Mondeo it is Simon.
Needs to be an automatic the manuals have the EDIS module built into the ECU.
The EDIS module is located about the middle of the fire wall and has EDIS 4 written on it a 100x75mm rectangle box about 20mm thick. Coil packs are easy to see and the VR sensor is triggered by the flywheel runs parallel to the crankshaft. You can also use a VR sensor off an EL EF falcon they are easier to come by and probably cheaper. Just need the EDIS module and coils from the Mondeo even other coils can be used like Lancer or Commodore as long as they are twin out put.
PostPosted: Thu Apr 02, 2009 9:19 am
thanks Ben - I went to a local wrecker yesterday and we found an EDIS module on a car - I took in a photo showing the bits I need, because the wrecker didn't know what they were either.
the motor was out of it already, and he wasn't sure where, so he's gonna locate it and give me a call when he's got everything - $110
thanks for the tip on the coils - the mondeo one is a bit ugly, and I don't like the plug end of the leads, looks funny :roll:
PostPosted: Wed Jun 10, 2009 3:29 pm
What year MOndeo would be a good source of EDIS and Coils - I think they've been making them from about mid 90's right through to now.
PostPosted: Wed Jun 10, 2009 4:24 pm
90-93 ish appears to be the range - like I said I took in the photo and showed the guy what I wanted...
After showing my dad, and a few people at Hay I need to track down another couple of setups.
I so impressed with how well it runs - been on for a few weeks now with a map I got from the megajolt website (autosportlabs.com/.net/.org) submitted by KLAS, who is also a member on here - it's a very good starting point for my engine - my mate and I will get it on the dyno soon and get it spot on
I do need to thank Ben (92) and Peter (pristic) for answering my questions about it all :D and Ben let me copy his trigger wheel
here's the photo I took in, from the post I linked to previously
PostPosted: Thu Jun 11, 2009 8:58 am
Very impressive, Simon... gotta be worth at least a dozen places at Hay? 8)
PostPosted: Fri Feb 12, 2010 12:54 pm
Sorry to drag up an old thread BUT...
I purchased one of Ben's fantastic trigger wheel kits only to find it won't clear my Minispares timing belt cover. (I already had to trim the original A+pully to make it fit in the first place.)
Does anyone know of a way to get a crankshaft pulley that sits out further from the timing case?
I'm not that concerned about having to space out all the other ancilaries to line up as I'm fitting a daihatsu alternator conversion at the same time, but definitely want a pulley with a damper on it.
I know another and possibly cheaper option is to put the trigger wheel on the outside of the pulley but who wants to have to remove the trigger wheel sensor every time you want to take the fan belt off?
2008 Prado GXL
PostPosted: Fri Feb 12, 2010 1:27 pm
I did one for pristic, I welded a steel hub to a Falcon trigger wheel and then machined it to locate inside a 1098 harmonic balancer.
2 5/16 UNF bolts held it to the existing puller holes.
The trigger wheel was outside the pulley.
Pics are in pristic's thread somewhere.
PostPosted: Fri Feb 12, 2010 1:30 pm
any further out and it'll have problems clearing the front engine mount, and besides that, you won't get a replacement fanbelt past the harmonic balancer. But I guess the front engine mount could be relieved a little
if you put shims between the end of the crank and the harmonic balancer, it might space it out enough, but be careful because it gives you another cause for the bolt to come loose and the harmonic balancer to wreck your crankshaft
PostPosted: Fri Feb 12, 2010 11:08 pm
I was about to start searching for a thread like this.
Do people still have the brackets and trigger wheels for sale?
I just got megajolt and im looking to put it on my 998 while ive got time to play.
Simplify and add lightness
Users browsing this forum: No registered users and 24 guests
