It is currently Tue Jul 15, 2025 5:23 am
PostPosted: Thu Jan 28, 2010 7:26 pm
Also used on MiniMatics and some Mokes.
WTF are these things so expensive?
My mate and I want 4 pair of them, and the only place in Oz that seems to sell them now wants $22 for each 1/2 collet... :shock:
So I think there may be a much cheaper DrMini ST version coming soon, let me know if you need any.
PostPosted: Thu Jan 28, 2010 7:30 pm
You can get them for half that from the UK.
http://www.minispares.com/Product.aspx? ... %20COLLETT
Cheers Pete
PostPosted: Thu Jan 28, 2010 7:43 pm
MSC:
"This item is presently out of stock. See below for any alternative items".
(none)
. Somerfords lists them, cheaper, but really they would be a piece of p!ss to make. :wink:
PostPosted: Thu Jan 28, 2010 11:23 pm
Harden them if you`re gonna make em
PostPosted: Fri Jan 29, 2010 7:46 am
Hi Kev,
I'd take a cuppla sets and it would be nice if they came with the seal washer too.
Regards
Al
PostPosted: Fri Jan 29, 2010 9:11 am
What do they do? :?
PostPosted: Fri Jan 29, 2010 9:19 am
They go (2 per side) inside the Hardy Spicer drive flanges on the diff output shafts. They are split so you can get them into the groove machined in the flange.
A bolt goes through them into the end of the shaft, effectively they locate the drive flange on the shaft. A rubber seal goes against them (behind the bolt) to seal oil in.
The old original ones I have don't appear to be hardened... so I was going to make them out of 1030 or 1040 steel.
PostPosted: Fri Jan 29, 2010 1:34 pm
Kev,
I don'tr think they should be too hard as they could be inclined to shatter and that could cause a problem or two. The originals appear to be made out of regular high grade steel and don't seem to suffer any problems.
Regards
Al
PostPosted: Fri Jan 29, 2010 1:47 pm
fwiw
http://www.bmc-parts.com/Webwinkel-Prod ... ollet.html
PostPosted: Fri Jan 29, 2010 2:31 pm
winabbey wrote:
Yeah not cheap eh.. for what they are- a machined washer cut in half! :lol:
PostPosted: Fri Jan 29, 2010 2:57 pm
A global business opportunity for Doc's Rare Spares could be on the cards :wink:
PostPosted: Fri Jan 29, 2010 6:15 pm
Hmmm... if I stamp a tiny `s' on them I can add Cooper S tax... :P
PostPosted: Fri Jan 29, 2010 6:59 pm
Nah, not worth the effort. Based on Mini adverts I've seen on eBay (and elsewhere) you just include the term cooper s in the product description regardless of what the part is or what's stamped on it (e.g. Cooper S front brake shoes, Cooper S magic wand gearbox, Cooper S rubber front floor mat, etc. etc.). :lol:
PostPosted: Wed Jun 06, 2018 12:17 pm
So 'drmini in aust' did you ever get round to reproducing the 88G493 collets? If so can I get 4 and what is your price posted to NSW 2324.
PostPosted: Wed Jun 06, 2018 12:20 pm
What is the correct way to insert these collets, with the chamfer in or out?
