It is currently Tue Jun 24, 2025 10:05 pm
PostPosted: Thu Jan 14, 2010 5:48 pm
Hi everyone,
Just wrote down quickly what colour wires go where at the back of a starlet GT. Its an ep82 1991 Automatic if theres any differences.
I cant test the circuits as ive got the loom unplugged, and its being picked up and taken away in a few days.
Any questions ask and ill try to answer.
Interior Light:
Red/White
Blue/White
Rear Wiper Motor
Blue
Blue/Black
Blue/Yellow
Spoiler Wires
Blue/Black
Blue
Black
Green
White/Black
Red/Blue
Brake Lights
Green/White
Green/Orange
White/Black
Right Indicator
Green/Yellow
White/Brown
Left Indicator
Green/Yellow
White/Brown
Tail Lights
Red/Blue
White/Brown
Simplify and add lightness
PostPosted: Thu Jan 14, 2010 5:50 pm
Hey, thanks for that, will probably be real handy soon.
Was there one for the fuel pump? Or is that in a separate part of the loom.
Madmorrie
PostPosted: Thu Jan 14, 2010 6:14 pm
Knew there was something i missed
Fuel Pump
White/Black
Blue/White
White/Black
Yellow/Blue
Yellow/Black
Theyre just the wires that go into it. I didnt have chance to rip the carpets up (only bought the car for the engine) so i think its the same loom.
PostPosted: Thu Jan 14, 2010 8:02 pm
Woo Hoo!! Thanks sooo much Joe. :D :D :D
I hope to rewire the entire Mini with the Starlet Loom/wiring so this is a massive help.
-Alan
PostPosted: Mon Jan 18, 2010 6:31 pm
Yes, good work Joe, info there for us all!
PostPosted: Wed Jan 27, 2010 2:56 pm
Fuel Pump
White/Black
Blue/White
White/Black
Yellow/Blue
Yellow/Black
Erm - there's 2 White/Black wires listed there ... It's ok - Here's bit more info for those wires (having just bought a fuel pump assembly from a 97 4EFE Starlet). This is what I have on my assembly :
White w/ Black trace - Fuel Pump ground
Blue w/ White trace - Fuel Pump power
Brown - Level sender
Yellow w/ Black trace - Level sender
Black w/ yellow trace - spare wire / not connected
Other info from http://www.toyodiy.com reveals that the 4EFE pump (Toyota part number 23221-46010) is the same for all 4EFE & 4EFTE engines in the EP8x range... and is also used in the old Paseo & some 4Runners, 2.2L Camrys, Hyundai Accent & Sonatas.
-Alan
PostPosted: Wed Jan 27, 2010 4:25 pm
Whoops, mustve missed that one. Cant even double check as the cars gone.
PostPosted: Thu Jan 28, 2010 12:06 pm
Hi All
Thought I'd chime in I sorted my rear wiring loom out a few months back.
Black w/ yellow trace - is for the fuel low level warning light on my EP82 dash cluster if I remember correctly.
Isaac
PostPosted: Wed Feb 03, 2010 6:16 pm
Was that on a 4EFE or 4EFTE?
-Alan
PostPosted: Fri Feb 05, 2010 9:14 am
Thats on my EP82 4efte half cut. I traced the wire from the rear loom plug (as I didn't have the rest of the rear loom) to the dash cluster. Its the ground for the low level warning light I wired mine up to a rheostat grounded on the fuel pump assembly (I'm using a mini EFI tank with a 255 walbro inside) works fine.
