It is currently Fri Jun 27, 2025 1:16 pm
Post new topic Reply to topic  [ 44 posts ]  Go to page Previous  1, 2, 3  Next
PostPosted: Wed Jan 13, 2010 7:16 pm
we are using a DPE manifold. I tried to find some information on them but no luck. I dont have any issues with firewall or cross member but I think they been given some adjustments
PostPosted: Wed Jan 13, 2010 9:53 pm
D.P.E............nup, got me Gaf :) ""looks"" good though.. (from what you can tell from a photo :) )
Obviously you like it yeah? How did you come to get it? I can't find anything on them either :?
PostPosted: Wed Jan 13, 2010 10:21 pm
Looks like a copy of the Oselli manifold... :)
@PK:
If everything fails; adjustable top engine steady? :)
My MG manifold was a bit of a downer... Casting was very rough and missaligned, and it had only a 1,6" opening :shock: Took me some hours with a grinder to get it right. http://img146.imageshack.us/img146/5628/hifvergl.jpg (left pic) But most other I've seen have a very good finish, though :) Still like it, my prefered manifold. And I think the MiniSport and new Spares manifolds are more or less good copys of the MG one.
Jan
PostPosted: Thu Jan 14, 2010 6:17 am
IMO if a manifold doesn't flow well there's no point using it.
The GR manifold outflows all the others hands down, it is worth the slight body mods needed to make it fit.
As Asphalt says, an adjustable steady would add a little room, if you are NOT running a remote box.
Here's how it fits in a stock `77 Clubby body (stock steady) with an HS6 attached-
With an HIF44 things get tighter- see how the carby is sitting high, because it's touching at the float bowl. The firewall would needs a heat & good thump with an XVBFH, earlier bodies need cutting as Aaron found out.
PostPosted: Thu Jan 14, 2010 9:23 am
I have not used a GR manifold but I can see that it would flow well. But a GR manifold is not water heated. Most non heated inlet manifolds I have had anything to do with are a pain, untill they warm up, causing flat spots, poor running etc. Has GRs design got around this?
Have a Nice Day.
PostPosted: Thu Jan 14, 2010 10:11 am
This manifold is popular up here, in Sydney nobody hooks the water up anyway.
My 1412 stroker had no flatspots running on the dyno. HS6 with OA6 needle. Not in a car yet.
PostPosted: Thu Jan 14, 2010 10:36 am
Impressive manifold!! :) How long is it, if you don't mind me asking? :)
PostPosted: Thu Jan 14, 2010 10:57 am
Port runner length is 7" :P but it measures 5-1/2" front to back.
PostPosted: Thu Jan 14, 2010 5:08 pm
Most water heated manifolds were designed for UK use, where winter temperatures cause problems, not really needed in Oz. In fact it can lose torque if connected as the cooler the inlet charge the better.
DPE could stand for Dave Price Engineering who did a lot of work with BL products in the late1970s including running the first works SD1 race cars in the British Saloon Car Championship around 1979-80.
Slide
1965 Mini Van (1360)
1970 Mk2 Cooper S (1310)
1978 Rover SD1 V8 (4.6)
PostPosted: Thu Jan 14, 2010 5:27 pm
Here in Melbourne during Winter I use a grill muff and a water heated manifold, if I did,nt have them I would constantly freeze the carby in the morning's or at night !!!!!
PostPosted: Thu Jan 14, 2010 5:59 pm
So, how do Cooper S etc get on with twin SUs on a dry manifold?
No water plumbing there... and they have heat shields to keep the carbs cool too. :lol:
Ditto for Weber DCOE... they are water free too.
PostPosted: Thu Jan 14, 2010 6:11 pm
This one does have water heating...
So err,,,, no one tried it?
PostPosted: Thu Jan 14, 2010 6:54 pm
Mods rock!
Gently heating the Inlet Manifold helps reduce emissions and helps a lot with fuel economy.
Yeah, up here in Sydney it just loses you HP. :lol:
PostPosted: Thu Jan 14, 2010 6:58 pm
Mods rock!
Yes, it will cost some HP, but I do like them for other reasons. It also helps them run a little smoother at low RPM / Low air flow.
