It is currently Fri Jul 04, 2025 10:26 am
Forum locked This topic is locked, you cannot edit posts or make further replies.  [ 52 posts ]  Go to page Previous  1, 2, 3, 4  Next
PostPosted: Mon Dec 14, 2009 9:05 pm
Good one Mick! :D
That thread'll be a CSP - Chinese Standard Pipe..................... :lol: :lol: :lol:
Rod.
______________________________
'63 Morris 850 (Old Secondhand CAR)
PostPosted: Mon Dec 14, 2009 9:35 pm
This space for rent
Sheesh, I'm an impulsive sucker :oops: :oops:
One grease pump and 500psi pressure gauge ordered and on their way :lol:
PostPosted: Mon Dec 14, 2009 10:23 pm
My apologies to the wife ;)
Let me know how you go with the coarse thread...maybe a visit to any other hydraulic supplier than the Enzed at Brooklyn might find a different answer :lol:
 Post subject: Try IFS
PostPosted: Tue Dec 15, 2009 8:00 pm
Try Industrial Fittings Sales - http://www.ifsaus.com.au/. Cannot guarantee the staff behind the counter will be helpful but if its a standard thread of some sort they should be able to sort something.... :D
Kevin
PostPosted: Fri Dec 18, 2009 6:09 pm
My red pot arrived today. Just waiting on the shrader chuck from USA
The unidentified thread is 16mm ISO course The pitch is 2mm. Hope this helps
Mk1 Cooper S
Mini K Rally car
PostPosted: Fri Dec 18, 2009 6:12 pm
So is that a simple metric bolt thread??
PostPosted: Fri Dec 18, 2009 6:22 pm
Yep, std ISO Metric coarse, as found on stock 16mm bolts. :wink:
see http://www.engineeringtoolbox.com/metri ... d_777.html
PostPosted: Fri Dec 18, 2009 6:42 pm
So if I wanted to move the gauge and valve up to the pump head, would an adaptor be available off the shelf? Or would it be a custom machine job?
PostPosted: Fri Dec 18, 2009 6:54 pm
Probably would need to make one (I can do in steel)- what thread is the other end? :wink:
PostPosted: Fri Dec 18, 2009 7:11 pm
Another option is to use the insert out of a Ryco field attach fitting.
Cut the taper off to length and screw it into one side of the "T". Screw a nipple into the other side hook up the hose and you're done.
PostPosted: Fri Dec 18, 2009 7:17 pm
One end of the hose is the 16x2.0 mm bolt thread, the other end is 1/8 NPT which poses no problems, the shrader coupler will screw straight on.
PostPosted: Fri Dec 18, 2009 7:32 pm
So you need a nipple, male both ends, M16x2.0 one end and 1/8 NPT the other?
I can do that... :wink:
PostPosted: Fri Dec 18, 2009 7:38 pm
hmmm...nearly...
To fit the gauge and barb at the top end you need an adaptor with:
16x2mm male one end, 16x2mm female the other end. A 1/8 NPT for the supplied valve and a 1/4 NPT female for the gauge.
How many Victorian Pesos would I need to send you Doc?
EDIT: I reckon you could swindle SGC into a second as well...he lives nearby and could share post ;)
PostPosted: Fri Dec 18, 2009 8:10 pm
I'm not sure if I can do it all by machining then, I have no M16 taps here.
They may have some at work, I can look on Monday.
Another easier way for me- I can use M16 threaded rod, with an M16 nut welded on the end for the female connection. Then machine the middle of the rod down to 14mm dia, and drill & tap 1/8 & 1/4 NPT connections into it. Screw a 1/8 NPT nipple in and Bob's yer aunty's husband. :wink:
PostPosted: Fri Dec 18, 2009 8:15 pm
Ahh yeah, that would work wonders...
