It is currently Wed Jun 25, 2025 3:29 am
PostPosted: Mon Jun 07, 2004 8:04 am
My mate has a rebuilt 1293 that is a bit worked, problem is that it has a massive flatspot when putting your foot down and it seems to die off and won't rev above 5500 rpm.
It only running a 1.5 inch SU (fully rebuilt) at the moment but will swap to twins soon.
Also has a standard 998 non-vacuum adv dizzy.
Ideas?
PostPosted: Mon Jun 07, 2004 8:44 am
I think carb. Get it on a dyno.
PostPosted: Mon Jun 07, 2004 9:12 am
I've just had carbie problems, and it sounds like it could be that.
That dizzy maybe the problem, but i'm no expert when in this area.
PostPosted: Mon Jun 07, 2004 9:17 am
I'v also had a simmilar problem. I checked everything from the fuel pump to blowing out the HIF44. Then I checked all the Elec Changed the points and condencer. It turned out after fitting the new point they were then closing again. I could not understand it. I would ajust the gap and then the same thing would happen. Thinking They were fine I went onto the next area. Try your points.
Gamfo
In the Hills
PostPosted: Mon Jun 07, 2004 7:24 pm
The reason new points close up is lack of lube on the cam, usually. This wears the points rubbing block.
Smear a little HMP grease on the cam. :wink:
