It is currently Thu Aug 14, 2025 10:19 am
 Post subject: turbo setup questions
PostPosted: Tue Nov 17, 2009 1:53 pm
hey guys
im just up to getting final things together for my turbo build
im running an 1100cc engine and around 7 pounds boost
does anyone have any suggestions on good compression ratios???
Thanks James
if i had my mini, i could of parked there!!
turbo 1100ccc engined 850 build & my blue deluxe
PostPosted: Tue Nov 17, 2009 5:04 pm
I'd say around 8:1 to 8.5:1 maybe 9:1 if the engine is built to handle the pressure :? .
PostPosted: Tue Nov 17, 2009 7:23 pm
thanks
im just worried about mt head coz there isnt alota meat left on it, so ile probably be looking at a decompression plate :?
PostPosted: Tue Nov 17, 2009 11:01 pm
Supercharged
should work on stock compression, avoid a decomp plate if you can.
do a bit of a search in this section and you'll find plenty of info.
PostPosted: Wed Nov 18, 2009 9:09 am
thanks will do,
what a disadvantages of a d/c plate?
would i be better off taking some meat from the compbustion chambers?
PostPosted: Wed Nov 18, 2009 3:27 pm
Supercharged
the d/c plate increases the chance you wont get a good seal on the head or the gasket, and it will increase the chance of blowing the gasket.
I havent had any issues with mine but i have seen/heard of others having issues.
take your cc's out of the chambers or the pistons if you can.
with only a modest 7psi you may not need to take much or any depending on how much your block/head has been decked.
my engine is running 8:1 but with 11-12psi
