It is currently Wed Aug 06, 2025 12:21 pm
PostPosted: Tue Nov 03, 2009 3:05 am
Hi!
Anyone runing such a system? Especially reliability would be interesting (such as durabillity of the catch valves).
Is it actually worth it for a road motor (1275cc, ~100hp)?
I'm probably going to fit a K head so good vacuume would help oil drain a bit I guess. But if you have to put in a new valve with every oil change (daily driven) I'd be quite annoyed :) It's not a race car...
And final question: what would be a sensible (negative) pressure level? I don't want it to suck all the oil out of bearings or such :)
Jan
PostPosted: Tue Nov 03, 2009 5:30 am
i could give you some parts ;)
just in case you want to try yourself
Rover 214 atm ....
PostPosted: Tue Nov 03, 2009 9:21 am
we had it in one of our speedway cars years ago (The superCharged one) , but it didn`t seem to be any different to the breathers just shoved into a catch bottle tho,,, altho it was "Less-smelly" in the engine bay
& sorry, no idea how low the pressure was,
PostPosted: Thu Nov 05, 2009 8:04 pm
I have no experience with it myself so I thought I'd consult vizard.
He claims power gains by using positive ventilation, aparantly his tests indicate around 2hp on a big bore engine.
He also says that he achieved up to 36" of water which is quite a lot!
A few points he makes are;
- after about 15" of water the seals start letting in air
- under vacuum the dizzy doesn't recieve enough lubrication and so it will need greasing regularly
- The dipstick will also let in unfiltered air
But on his diagrams he doesn't show any pressure limiting valve so perharps the pressure limiting is by design?
The 850 Man
PostPosted: Tue Nov 10, 2009 10:54 pm
Interesting :) Thanks so far! Looks like I have a little play with it ;)
@Klas: I'll come back to you. Might take a little time tho :roll:
Users browsing this forum: No registered users and 23 guests
