It is currently Tue Jun 24, 2025 10:08 pm
 Post subject: Instruments?
PostPosted: Sun Nov 01, 2009 5:42 pm
What are some of you guys using for Speedo's, Oil Pressure, water, fuel instruments etc besides the factory Suzuki/Toyota cluster?
I'm especially interested in digital dashes or speedo.
PostPosted: Sun Nov 01, 2009 7:12 pm
Digidash.
User selectable as to what information is displayed and in what format.
Tricky
PostPosted: Sun Nov 01, 2009 7:39 pm
I was going to run an Adaptronic ecu and have diagnostics screen as my dash. Shows me everything i need to know and has datalogging too.
But the digidash seems a better option, but ill see whats best when i get the money spare to get one.
Simplify and add lightness
PostPosted: Sun Nov 01, 2009 7:48 pm
Thanks for that Tricky.
I've had my eye on those but find the cost to be a little high.
I've also had my eye on the ACEWELL ones
http://www.acewell-meter.co.uk/en_uk/index.htm
I suppose it wouldn't be difficult to adapt anything to suit. It will be my primary display so hopefully it will get past roadworthy too.
PostPosted: Sun Nov 01, 2009 7:49 pm
I dont think it would be a problem......
PostPosted: Sun Nov 01, 2009 7:51 pm
The only problem i can think of is the speed, but any digidash worth anything would be able to link a speed sensor in.
PostPosted: Sun Nov 01, 2009 7:52 pm
b_d, does that mean you need to have a laptop in the car with you all the time?
PostPosted: Sun Nov 01, 2009 7:58 pm
No, the ecu would function as a computer, and you could either set it up with the gear ratios, then it would calculate speed off the engine rpm, or get a sensor off an abs car and rig it up so it reads like abs, except detects the rate at which the toothed gear spins.
Something like that i was trying to say.
