It is currently Sun Jun 29, 2025 6:26 pm
Post new topic Reply to topic  [ 1864 posts ]  Go to page Previous  1 ... 66, 67, 68, 69, 70, 71, 72 ... 125  Next
PostPosted: Mon Oct 26, 2009 7:02 am
nice work there tricky
how far out does the FMIC stick out!!!???
'94 Honda EG4 Civic. -Daily-
'95 Honda DC2 Integra
PostPosted: Mon Oct 26, 2009 8:23 am
Hi Alistair,
It sticks out about 2 inches (50mm) from the front of the sheetmetal, but the Zeemax front spoiler should cover it just fine and hide all the support bars and fittings.
No one has asked what the wings are on the sides of the FMIC.........????
PostPosted: Mon Oct 26, 2009 9:09 am
ok then , i`ll bite at that one,,, what are the wings for on the fmic ???
PostPosted: Mon Oct 26, 2009 9:31 am
This space for rent
Spottie mounts?
PostPosted: Mon Oct 26, 2009 9:38 am
I'll punt on some mechanism for spraying something on the cooler.
PostPosted: Mon Oct 26, 2009 11:02 am
To make it go faster?
Simplify and add lightness
PostPosted: Mon Oct 26, 2009 6:50 pm
Dose look good. What is that little red square welded on the front?
PostPosted: Mon Oct 26, 2009 7:16 pm
sgc wrote:
Spottie mounts?
Give that man a cigar - there is no getting things past you Simon!! :wink:
JC - the FMIC water spray nozzles actually sit in the front spoiler directly in front of the FMIC and spray a fine mist into the incoming air.
I bought a CMGS spray controller from Cooling Mist to control the spray pump for the FMIC water spray. It should work a hoot and it looks the goods too:
(Edit: New picture)!!!
PostPosted: Mon Oct 26, 2009 7:38 pm
Macro setting brother, macro.
PostPosted: Tue Oct 27, 2009 11:27 am
Kenno,
Its to hide the actuator can for the KKR280. The can is much larger than the one for the TD04L and it was interfering with the front apron. I just decided to cut a bit out of the front apron and then cover it again with a slight bulge - the red is actually the metal left over from the bonnet when I cut the Starlet scoop in - that's recycling for you!
It will all be hidden by the front spoiler.
Tricky
PostPosted: Tue Oct 27, 2009 12:51 pm
Looking good Tricky.
Cam did a nice job on all the alloy welding for the intercooler and stuff. Good work Cam.
mmmm i would love to come around and play with all those new toys one day Tricky oh i would have so much fun. I used to love metal work at school.
The Cat would be going in soon to get her fure coat soon wouldn't she Tricky.
Cheers Dan
Cheers Dan
PostPosted: Tue Oct 27, 2009 5:35 pm
Nice toys Tricky!
When will the billet alloy conversion subframes be available??
Madmorrie
PostPosted: Tue Oct 27, 2009 7:18 pm
Dan,
Yes Cam did a real good job on the pipework, he is a good welder.
Come around anytime if you like.
Yes, The Cat is due to go to the spray painters at the end of this month/early next month and I cant wait. It is going to be such a change from 'Ipswich Grey'.
MM,
Yes, the toys will definitely come in handy, I have only a few more things to get and I am done! Billet alloy subframes - hmmm, now there is a thought! :wink:
PostPosted: Tue Oct 27, 2009 10:27 pm
What other toys do you plan on getting you almost got everything now.
Dan
Cheers Dan
PostPosted: Tue Oct 27, 2009 10:30 pm
Shall we put bets on?
I think powder coating oven.
