It is currently Wed Jun 25, 2025 1:08 am
PostPosted: Thu Oct 15, 2009 9:42 pm
Howdy guys,
it has probably been brought up before but i couldn't find it, but the reverse system available with the Zcars motorbike rear engine conversion kit, is this road legal here in australia (south australia to be more precise)?? I am just wondering at the moment as i am in no position to start this build, i am simply trying to get my head around what is needed.
Brendon
PostPosted: Thu Oct 15, 2009 10:06 pm
1st step - talk to an engineer in your area. Chances are - no. Have a search on the site as this was a hot topic a month or so ago.
1964 Nb Race Car - big bore short stroke & lots of revs - Sold
1969 Mk2 Cooper S - First Car
PostPosted: Fri Oct 16, 2009 4:41 pm
electric reverses are fine from what ive been told.. why wouldnt they be..
Potato
PostPosted: Fri Oct 16, 2009 4:47 pm
Didn't the Goggomobil have `electric' reverse? You started the engine to run backwards..:mrgreen:
Pretty sure there is an ADR? rule excluding electric motor reversing though. There's a rule for everything...
PostPosted: Fri Oct 16, 2009 5:15 pm
No, don't tar the Goggo with that brush :P
You're thinking of the Lightburn Zeta
It had th same maximum speed backwards as it did forwards :shock:
Luckily, it wasn't that fast in either direction.
PostPosted: Fri Oct 16, 2009 7:26 pm
I don't think the problem is in the reverse being electric (look at prius for example) but rather in the bike engine conversions most people don't generally put a variable speed drive in to control the reverse speed accurately. Most simply put the battery direct to a starter motor which of course will only move the car at one (nominal) speed and it would be rather jerky too.
PostPosted: Wed Oct 21, 2009 6:38 am
As did the Austin Champ - it was 4l Rolls powered, but weighed as much as the sun, so also not fast in either direction!
PostPosted: Wed Oct 21, 2009 6:50 pm
Likewise the old MB Unimog from years ago.
PostPosted: Wed Oct 21, 2009 6:53 pm
I had a truck with two reverse gears, too fast and too slow! So most times you used "too fast" and kept the foot away from the throttle. :shock: :lol:
PostPosted: Wed Oct 21, 2009 7:25 pm
Quaife do some differentials for that purpose:
http://www.quaife.co.uk/Differentials_3
But I guess 'POA' means "if you have to ask you can't afford it" :lol:
PostPosted: Thu Oct 22, 2009 10:26 am
Jan it`s about $6000 landed here, inc all freight & import taxes etc
I`m pretty sure that`s the one i will be getting for my hillclimb special (when i can source the funds tho obviously--> maybe in a few years :-( )
we actually have this buggy inside my shed again, up on stands, stripping it down for final fiddly things, painting & cladding in alloy sheet,,, we should be on the track with it next year (minus the reverse gear at this stage tho)
