It is currently Mon Jun 23, 2025 7:43 am
Post new topic Reply to topic  [ 377 posts ]  Go to page Previous  1 ... 11, 12, 13, 14, 15, 16, 17 ... 26  Next
PostPosted: Sat Mar 12, 2005 10:25 am
I just picked up my D4R83 today,got dizzy and ECHILIN "high performance" coil for $50..
it will be swapped over later 2day when i grab my old dizzy out the thrash motor.should be good
next weekend it will be in
im thinking about taking to a auto elec. place and having it pulled apart and totaly rebuilt?will this do much for it?new cap,rotor,leads,plugs and GT40R coil B4 she drops in :D
BRICKWORX RACING
872-874 South Rd
Edwardstown
SA 5039
PH: 8297 9494
FAX: 8297 7133
PostPosted: Sat Mar 12, 2005 4:50 pm
Save your money, leave it in 1 piece. The only part that ever stuffs up is the vacuum can. :wink:
PostPosted: Tue Mar 15, 2005 6:07 pm
Will these go into a A+ block as easily as they do into an A?
Mini - The Wizardry on Wheels!
PostPosted: Tue Mar 15, 2005 6:21 pm
Pretty much. I'm about to fit one into our 1293A+.
Only differences- fit A+ drive dog & pin, and file or turn the 3 casting fins off the body so the A+ clamp will fit.
Diameter and length are OK.
Easy peasy. :wink:
PostPosted: Thu Mar 17, 2005 6:17 pm
WOW!
i just put mine in last nite,and got it running 2nite
there is a HUGE diffrence between the 2,my car is so rev happy,and thats with my old plugs still at .25thou gaps
ill get new plugs and leads next weekend and have it tuned,and it will be awsome :D
carnt wait for super sprints now :D
BRICKWORX RACING
872-874 South Rd
Edwardstown
SA 5039
PH: 8297 9494
FAX: 8297 7133
PostPosted: Thu Mar 17, 2005 6:51 pm
Wow, I just fitted mine last night too!
Very easy job and the car starts well and pulls better from lower revs. I think the advance curve suits it better. Still have to open up the plugs and get the timing right.
I will see what the fuel economy figures come up like as I have kept a record of the economy since I bought the car in 1998 so any major difference should show up.
No problems with clearance in the engine bay of a Morris 1100 :lol: And the ice cream tub still fits over the dizzy cap.
PostPosted: Thu Mar 17, 2005 7:00 pm
car also sounds betr,more crisp when revving,AWSOME!
BRICKWORX RACING
872-874 South Rd
Edwardstown
SA 5039
PH: 8297 9494
FAX: 8297 7133
PostPosted: Thu Mar 17, 2005 9:40 pm
At First i thought something was horribly wrong... it used to sound like "dub, dub, dub" now its more "rap, rap ,rap" . . sounded REAL LEAN to me.... check ed plugs.. PERFECT ... hmmmm
quick email to kev, "Yep, that means its working" .... Phew! :P
Still spooks me though.... (Lean+Turbo = $$$)
made my re13 998 SO MUCH more drivable. . . . its actually usable below 3000now !!
Nice work Kev
J
PostPosted: Fri Mar 18, 2005 6:03 am
I like the way it keeps firing `em properly, to 8,000 and beyond.. pretty good `speed equipment' for $40! :P
PostPosted: Fri Mar 18, 2005 8:03 am
maybe I should dust mine off and actually fit it.... :lol: I've had it for a while now.... :?
Promising feedback though!
PostPosted: Fri Mar 18, 2005 5:57 pm
It only takes an hour to modify it and fit it. Don't hang around! Do it!
I cut the lug off the dizzy with a hacksaw and then filed it round with the angle grinder :twisted: Dressed it up with a file and then drilled the hole out. It takes longer to find the tools than doing the actual job!
PostPosted: Fri Mar 18, 2005 6:40 pm
If you clamp the angle grinder `gently' in the vice and fit a flap (linishing) disc, it makes a dandy linisher.. gives a nice finish on most materials. 8)
PostPosted: Fri Mar 18, 2005 8:57 pm
what dissy would be best for my car it is a 1144 i think and has twin carbs ands i very lumpy idle :)
im gonna go look for a pulsar dissy shortly and im not sure which one to get
Pulsar auto- D4R83 :?
Pulsar manual- D4R85 :?
also i have this coil at home it is a bosch gt40rt super sports coil 12v and was wondering if that would work with the pulsar dissy or to try and get a pulsar coil with the pulsar dissy :?
PostPosted: Fri Mar 18, 2005 9:02 pm
Either dizzy will do, 85 probably best if engine is modified.
No that coil will not do- it's a 3 ohm (12V) one. Pulsar dizzy uses a 1.5 ohm.
Just grab the Pulsar coil, with the dizzy & cap. Note the blue wire goes to <-> on coil. :wink:
PostPosted: Fri Mar 18, 2005 9:06 pm
ok so ill need the coil and dissy and cap is there anyting else ill need as i might have a look in blaxland wreckers tommorow :)
