It is currently Wed Jun 25, 2025 6:49 pm
Post new topic Reply to topic  [ 207 posts ]  Go to page Previous  1 ... 8, 9, 10, 11, 12, 13, 14  Next
 Post subject: Re: Original
PostPosted: Tue Sep 22, 2009 11:38 pm
Linehaul wrote:
Hi Guys,
Thanks for the reply(s).
I am disapointed if its not genuine, was planning the full resto as an investment/sunday car. Not sure if i wanna spend the hard earned cash if its not.
I found the link from where i bought it. I must admit, at that time (and now) i wasnt really in the know when it came to identifying the keys...cheers and thanks again.
http://www.ausmini.com/forums/viewtopic ... 75+geelong
Jimbo.
Mine is:
XNFAD18Y/102918 - July 78.
The engine number is 12H87UH002232
Alec
PostPosted: Wed Sep 23, 2009 8:48 am
Linehaul wrote:
Hi Guys,
Jimbo.
Is everyone saying that this is an 1100 not a 1275? If so you cannot blame the buyer for being slightly disappointed that it was advertised on the forums as a complete, genuine and original LS with 1275, not only by the last owner, but also backed up and posted by poeee, yet it appears that this is not the case at all. I would have though such things were verified before it was put up for sale, and such claims were verified genuine....
I'm am not trying to get anyone's nose out of joint, but if both the last owner and poeee both claim its a genuine 1275 LS, one would think that its a valid, credible source of information.
Just my 2c.
I am of coarse referring to the below which is the text from the sale thread:
poeeel wrote:
Pete at Bellarine Mini Centre is shifting house and needs to sell this 1275 LS.
It's complete (got all the 1275 LS stuff) and genuine. Long range tank, 8.4" discs, 12" rims including 12" spare (only 3 hubcaps), 1275, seats, 3 guage cluster, heated rear screen, etc all still there.
It is drivable. The engine runs, but is smokey. Gearbox is good.
Rust wise, it's pretty good. Pete recons there is some in the floor (he lifted the carpet up to show, but I couldn't see any thing but surface rust hehe).
Price is $3500ono. Contact me.
Economic transport to anywhere in Victoria if needed!!! The car should be up at the Mini Experience show at Mt Cooper in Bundoora on the 26th if not sold before then.
Pix...
PostPosted: Wed Sep 23, 2009 9:11 am
This space for rent
No, the motor is from a Morris 1100S, not a Mini.. it's a 1275, just not a genuine LS. It's still a good motor, just not original.
PostPosted: Wed Sep 23, 2009 9:12 am
Ahhh right.
That makes sense then. But its still not "genuine" as claimed right?
PostPosted: Wed Sep 23, 2009 9:25 am
This space for rent
adzzza wrote:
Ahhh right.
I'd consider it a "genuine" car myself.. but obviously not "matching numbers".. but then it wasn't advertised as such.
PostPosted: Wed Sep 23, 2009 9:45 pm
Can anyone categorically state that the motor isn't the original. If the Vins are reliable and the engines could be numbered out of sequence is it not possible that the early cars used whatever 1275's they received until the 12H902U's arrived?? My case in point is the few 12H897U's that have turned up and this 12YTAH....
Alec
PostPosted: Thu Sep 24, 2009 8:20 am
Mods rock!
There were actually two sets of different numbers used for the 1275 LS - just to make things easy for all of us!!
It appears the 'earlier' models had the body prefix of 022X2S4M09 and it should be fitted with an engine having a prefix 12H897/U.
The 'latter' models had the body prefix XNFAD18Y and should be fitted with an engine 12H902/U.
I'm trying to establish when the number system changed, but it appears it was around September 1978 - perhaps someone could shed a bit of light on this.
Interesting also is that (at least some) of the factory information says that production of the 1275 LS didn't commence until August 1978 - now there's an eye opener for you guys with the July Plated models :shock:
The 12H/389/SH engine is from an english 1275 GT.
PostPosted: Thu Sep 24, 2009 5:57 pm
There is a lot of myths about prefixes around. Nearly every list I have seen has a lot of mistakes and these mistakes keep getting passed along.
The prefix 022X2S4M09 is for a 998 LS not a 1275. See the 09 on the end of the prefix? that stands for 998cc. :wink:
As far as I know all 1275LS's were made after the change in code to the new type (the bulletin for the change of code was dated 24 April 1978). So they should all have the XNFAD18Y code.
The 12YD/Ta/H prefix is a Morris 1100S prefix. There is no possibility of a Morris 1100S motor being fitted to a 1275LS from the factory. It just didn't happen. It was 9 years later and the two motors are very different in spec.
PostPosted: Fri Sep 25, 2009 12:43 pm
Mods rock!
Yes, the 09 is supposted to mean that it is a 998, however I've worked on way too many factory genuine 1275 LS's with the 022X2S4M09 body prefixes for there to be a coincidence. I did thoughly check these cars as I thought the same, and either they are real or a lot of people have gone to a lot of trouble.
Over the years I have come across a lot of factory 'funnies' and reading other peoples experiences and noted discrepancies it is pretty obvious that despite the good system of coding that the factory developed and all the unique parts for particular models, the reality of what happen on the production floor is quite different to all this. One clear example of his that we all know of is the latter Cooper S's, from around 1969 - I doubt that any two that rolled off the line where the same and none of them 'line up' with the parts books.....
PostPosted: Fri Sep 25, 2009 5:33 pm
All the 1275LS's were built after the code system changed. There is no chance of a 1275LS wearing a plate with the 022X2S4M09 prefix. That system was finished at the end of April and the 1275LS came months later. There was no going back.
Any car with a 022X2S4M09 prefix would be a 998LS, even if someone fitted a 1275 motor later.
As for the rolling changes through the life of the Cooper S I don't think that there are any great mysteries in them. They introduced changes as old parts run out and new parts were developed. They didn't build one with a Lockheed booster and the next with a PBR and then go back to a Lockheed. They just made a change and moved on. There are no secrets left unsolved.
We know the approximate date of each change in the production run of the Cooper S.
 Post subject: 1100s?
PostPosted: Fri Sep 25, 2009 6:29 pm
Hi All,
Thanks for the info, my apologies if i sparked a debate.
A question, just out of interest, if i have an 1100S, what is the difference between a 1275 and what i have? Would the current motor i have still be worth a re-build, or would the output be significantly less? I know this question is probably in the wrong thread now...
Jimbo
PostPosted: Fri Sep 25, 2009 6:37 pm
The motors are nearly the same. After this time the main difference will be the stamping of the engine number.
If you rebuild the motor there will be no difference between the output of the two engines.
Most modified cars use the motor out of the Morris 1100S as there are more of them around.
They made 1000 1275LS's.
They made over 15,000 Morris 1100S's.
You can see why so many cars have the wrong motor. :lol:
PostPosted: Fri Sep 25, 2009 9:49 pm
Ok. What I'd like to know is this:
Mine has an engine that is 12H897U (but with the 9 missing thanks Leyland :? ).
I can see no other minis that use this number on the lists other than the suggestion that some other 1275LS's had them. So what does the 897 mean compared to the 902 and how does anyone out there know for sure that 12H902 was the only code on 1275LS?
If someone has the magic book of Vin/engine numbers, where do I get my copy?
Alec
PostPosted: Sun Sep 27, 2009 12:53 pm
Mods rock!
Refer my posting 3 up.
PS I never said they went 'back and forth' with parts, only that there were a lot of differences in the same model.
 Post subject: Orignal
PostPosted: Wed Sep 30, 2009 11:42 am
Hi All,
Just an FYI (since I feel responsible for starting the LS1275 engine side discussion).
I sourced my 12H902 engine block today. Got it for just over $200.
Now, onto the original resto......
Thanks for everyones advice and input. Cheers.
Jimbo.
Users browsing this forum: BBY755, MINI66, winabbey and 81 guests
