It is currently Mon Jun 23, 2025 7:00 pm
Post new topic Reply to topic  [ 377 posts ]  Go to page Previous  1 ... 22, 23, 24, 25, 26  Next
PostPosted: Tue Aug 04, 2009 9:50 pm
GAHHHH!!!
Smashing the pin from the Lucas dizzy is a nightmare!!! So tempted to drill it out and find a replacement pin.
1965 Morris Mini Deluxe - 998cc SC12
PostPosted: Thu Aug 13, 2009 12:44 am
Did anyone have a tacho installed with the pulsar dizzy?
Before I had the sender for the tacho on the -ve side of the coil but now it does not seem to work with the same configuration. Took the volt meter out and placed it across the +ve and -ve terminals of the coil and found I got different readings from the old dizzy setup. Old one pulsated on and off reaching 12v, now I read a constant 3v.
PostPosted: Thu Aug 13, 2009 10:13 pm
I've not done a voltage test on there but most tachos work OK with a Pulsar dizzy, including Smiths.
4myego just fitted a new Smiths tacho in his, it's working fine.
I run a Veglia Borletti (ex Fiat) it works fine too.
I had an early Smiths one in the wife's S replica, it worked fine but read high on hot days (old tacho problem).
All these cars running Pulsar dizzy.
<edit> If I recall correctly from past threads, some cheapo tachos do need a diode in the sensor wire to work properly with electronic ignition.
PostPosted: Fri Aug 14, 2009 8:52 pm
have to get you to check our Pulsar dizzy with our ? brand Tacho also then, Looks fine thou
PostPosted: Mon Aug 17, 2009 8:49 pm
Hmmm, I have a cheapo tacho from ebay
http://cgi.ebay.com.au/MARS-2-5-INCH-60 ... 286.c0.m14
Might have to invest more in a better one then :(
I'll try putting a diode on the signal wire first to see how that goes.
Thanks guys
 Post subject: Success
PostPosted: Sat Sep 19, 2009 5:11 pm
Hi guys, i bought a couple of these dizzys from the wreckers and built one good one out the the three, modded the plate etc and lubed it all up. Fitted on the engine like a glove and tunes up like a beauty. Wow what a difference it has made to the engine. Cold start now is like a 2009 EFI car, no missing or carry on. Very pleased!
I do notice the engine still pings a tiny bit here and there under ceratin loads at around 3500rpm but i am sure this is related to the carby tuning as it is not setup correctly.
:D
PostPosted: Mon Oct 19, 2009 12:24 pm
is the pulsar dizzy the same as a silvia dizzy?i had a silvia dizzy on my metro when i got it and it wired straight up to the tacho and ran fine, just had 2 wires going to it.as far as i could tell it just went straight to it no problems.
PostPosted: Wed Dec 16, 2009 9:32 pm
It could be the same, I believe the body size was standard on most Nissans.
I have recently acquired a 1979-82 Honda Civic one, these do need a bit more modding to fit but they work OK too.
I know there is also a Subaru one that works, a member here has one in his Moke, but I've not eyeballed it to ID what Suby model it's off.
PostPosted: Thu Dec 17, 2009 1:27 am
Hi,
Should be from some Subaru models with 1800 carbed engine, from mid/late 80's .
rgds,
Luis
PostPosted: Sat Jan 30, 2010 9:18 pm
Note on reassembly of Pulsar dizzy:
The star is fitted with the numbers on top. It won't spark properly otherwise.
Spark occurs when the steep side of the star leaves the polepieces.
PostPosted: Wed Jun 09, 2010 10:14 pm
I'm gonna try to source a pulsar dizzy this weekend, I reckon I'll get one for my mini cos I'm not that keen on playing with advance curves on my supercharged morris 1100S, detonation + boost = sadness.
if I can get one into my mini easily and cheaply enough ill try one on my 1100 though.
The fleet:
1949 Fiat Topolino
1965 Morris 1100
1966 Mini Van (project)
19?? Morris 1500 (for sale)
1979 Chrysler Regal
1990 FSM Niki
PostPosted: Sun Apr 01, 2012 8:54 am
BUMP.
Mine is a d4r83-39 too, if the 39 is the advance that's not ideal at all.
Also with spark plugs the higher the number the colder the plug. I usually run 2 units colder in the 205.
Toyota Celica GT-Four ST205 Group A Rallye..350kw atw
Toyota Mark X 350s, Australia's first.
No mini :(
PostPosted: Sun Apr 01, 2012 1:19 pm
I believe the `39' or whatever number is the vac can spec, I leave them disconnected (most have a blown diaphragm anyway).
They are just an economy device for low performance engines... :P
PostPosted: Sun Apr 01, 2012 7:58 pm
Not quite true, completely up to brand i.e. NGK the higher number is Colder but with Bosch the higher number is hotter.
PostPosted: Sun Apr 01, 2012 8:19 pm
Ahh right, I only ever use ngk (jap cars is what I work on 99% of the time), learn something new every day.
EDIT: I had a blonde moment today when playing around with the pulsar dizzy.
No mini :(
