It is currently Fri Jun 27, 2025 2:15 pm
Post new topic Reply to topic  [ 1864 posts ]  Go to page Previous  1 ... 58, 59, 60, 61, 62, 63, 64 ... 125  Next
PostPosted: Sat Jul 18, 2009 8:46 pm
Hi Everyone,
Time for an update.
I have been working feverishly in trying to get the car ready for painting, which, by the grace of God s due to be done on the 1st August. Now to get the car right for the booth, is a big task as you want every hole drilled, every weld done, everything installed so you wont mark the good paintwork when you reinstall everything. There is nothing worse than getting your car back from the paintshop only to realise you have to drill some holes somewhere because you forgot something :cry:
Anyway. I started on the ICE install. I didnt like how I did it last time so I redid the whole thing. The speaker arrangement hasnt changed, just the way that they were done. I wasnt overly fussed on the carbon fibre in the end, so I just redid all the three enclosures in MDF, which will eventually get painted.
And from the back:
Next up was tackling everything that has to be done under the engine bay, and that means pipework. All the charge air pipes are in 2.5" polished alloy, so I enlisted the help of my good friend Cameron (Cazmo on here) to do some alloy welding for me. Now, doing pipework is not easy and it takes a fair bit of time to do it right. This is where we got to at the end of day 1. The pipe from the intake plenum to the intercooler almost done.
The airbox was also installed, and holes drilled into it to take the inlet and outlet pipes. A reinforcing ring was welded onto the grill louvres to secure those seeing that a 2.5" holes was cut into them:
We had to do a bit of alteration to the radiator to make the pipes fit. Now the radiator was designed way back when I was going to run the standard CT9 and top mount intercooler. Not that we are running a different turbs and intercooler setup, the inlet throat and cap fouled with the pipework from the airbox to the turbo. So, that had to be moved into the corner. Also, while we were at it, we needed to weld some tabs on the radiator to mount the thermo fan.
Talking about alloy welding, I drew up the design for the FMIC water spray tank. Using 2.4mm alloy sheet, I cut it out and bent it up so that Cameron could weld it up. Here it is in position. It still needs to filler neck and outlet barb for the pump welded on.
The last job I have been tackling lately is the doors. I wanted to make new door cards up that were flush with the inside of the doors. I had removed the pockets from the doors a long time ago and really liked the pocketless look. It makes it look a bit more streamlined and purposeful. At the moment I am having trouble with the clearances with the door opener on the inside, and also the window winder fouling with the speaker pods for the 6.5" component speakers. Just something else I will have to sort out. I am thinking abut running electric windows and doing away with the winder altogether. This would compliment the central locking. Now, before the doors are installed, I have to make sure the door handles work, the central locking works, the keylocks (which are integral with the Civic flush external door handles) work, the speaker pods are gragfted onto the door cards, and the cards drilled and fixed to the door. All this before any paint hits the door. Big ask.
Anyway, I will post another update soon. Anyone had any success with electric windows in a Mini??
Tricky
PostPosted: Sat Jul 18, 2009 8:57 pm
Nice work as usual Tricky.
Bring on August 1st, can't wait to see it painted!
Madmorrie
PostPosted: Sat Jul 18, 2009 9:01 pm
lookn good tricky, i bet your getting excited about getting it painted soon.
how you plan on attaching the door cards to the door as i'm doing the same with my doors.
cheers dan
Cheers Dan
PostPosted: Sat Jul 18, 2009 9:42 pm
Dan,
Come round, I need advice and help!!!
My interior handles just arent working!
I was planning to nutsert a row of 6mm domed allen bolts around the perimeter of the door cards. This would then be consistent with all the other fixings I have used.
MM - thanks for the kind words. Yes, bring on August 1st (or soon thereafter) :D
Tricky
PostPosted: Sat Jul 18, 2009 9:43 pm
Give Ash some flowers Nick .
Nice Tricky. Looking forward to seeing it completed at this years Muster :mrgreen:
PostPosted: Sat Jul 18, 2009 9:44 pm
Oh, forget to mention, got this for my birthday - cant wait to fire it up in anger!!
PostPosted: Sat Jul 18, 2009 10:17 pm
oh yeah, happy birthday for the other day trickster,,, sorry i`m late,,, i`m always late :-)
PostPosted: Sat Jul 18, 2009 10:28 pm
tricky
i would love to come around sometime soon, what day is good for you i'm free all week except friday and next sunday so if any of these days are good for you let me know and i'll come around.
cheers dan
Cheers Dan
PostPosted: Sat Jul 18, 2009 10:31 pm
What about next weekend Dan? Say next Saturday??
Thanks Matt - better late than never eh??
PostPosted: Sat Jul 18, 2009 10:54 pm
oh sorry man i was ment to say i'll be free next sunday i'm busy saturday. sorry man
cheers dan
Cheers Dan
PostPosted: Sat Jul 18, 2009 11:09 pm
This space for rent
Mmmm, gotta love deadlines. Nothing like an appointment with the spray painter for a little motivation, eh? :D
Every time I see your exhaust manifold I go 'wow, that's a nice piece of work' 8) It's the little things, quality :lol:
Looking forward to more progress, can't wait to see how the Cat comes up in colour!
(oh and a big HAPPY BIRTHDAY!! for the other day, sorry I missed it.. didn't have you in my calendar :( )
PostPosted: Sun Jul 19, 2009 8:25 am
Dan, Sunday is good!
Simon - thanks bro. Yes, I seem to work better to deadlines I'm afraid (just goes to show how poorly I manage my own time I guess :? )
Anyway, the car is set to go to spray painters on he 1st, it should take 3 weeks before I get it back. Yes, I am very excited, and very nervous. so many things to do. :shock:
OK,for everyone reading this thread -
1) has anyone re-bushed the hinge pins in their boot hinges?
2) has anyone ever installed electric windows in their Mini's (dont bother answering if you have sliding windows!!)?
3) When running cables through the door jambs to the doors (for speakers etc), is there a problem with pinching of the cables between the door and the jamb?
4) The trim piece for the C-pillar, has anyone got a template for this?
Thanks everyone for your kind words and help.
Tricky
PostPosted: Sun Jul 19, 2009 8:47 am
Looking good as usual Tricky. SO looking forward to seeing it painted. I'll be at the muster this year too so will love to ogle over El Gato in the flesh.
Might have to have an Amber or two with you too.
Dicko
PostPosted: Sun Jul 19, 2009 9:32 am
I have seen braided covers made to go over the wires so that they don't get pinched or anything like that... Was going to do something like this on my van, but am no where near that stage yet.
Life's a garden.... Dig It!
PostPosted: Sun Jul 19, 2009 10:55 am
This space for rent
I've only got really thin speaker cable in my car (I don't listen to it anyway) and no grommets in the A-pillar so the cable tends to slide in and out as the door opens and closes.
Most new cars tend to use a concertina rubber conduit, perhaps you could pinch something from, say, a 4WD Honda? :lol:
