It is currently Tue Jun 24, 2025 3:11 am
Post new topic Reply to topic  [ 377 posts ]  Go to page Previous  1 ... 10, 11, 12, 13, 14, 15, 16 ... 26  Next
PostPosted: Wed Mar 02, 2005 8:50 pm
You get a fatter stronger spark which allows you to run a bigger plug gap, which means more efficient burning and more power.
You never have to adjust the points gap again, and you get a clean rev all the way through the rev band and up to 8000k if you so want to. Stock will get all floaty and inaccurate around 6k..
PostPosted: Wed Mar 02, 2005 8:53 pm
ok i see now :)
PostPosted: Wed Mar 02, 2005 9:34 pm
if my 1100 ever seen the sunny side of 8000RPM i would sell it and never speak of it again :shock:
BRICKWORX RACING
872-874 South Rd
Edwardstown
SA 5039
PH: 8297 9494
FAX: 8297 7133
PostPosted: Wed Mar 02, 2005 9:36 pm
Mine goes to about 6 grand...
Then valve bounces. :twisted:
Mmmm thats when i back off.
Who cares, its only an engine. :)
PostPosted: Wed Mar 02, 2005 9:48 pm
Mine has seen 7k and pulled all the way..will pull to 8...1100's ain't THAT bad..sure the crank cracks eventually but it does take a while..
Ask the doc, his old 1220 revved to 8500 regularly and lasted 20000miles...
Then it's time for a new motor :wink:
its only getting to work for a week,most people here,when they brake it,they fix it.mini tec dont brake your motor,but will fix it :roll:
BRICKWORX RACING
872-874 South Rd
Edwardstown
SA 5039
PH: 8297 9494
FAX: 8297 7133
PostPosted: Wed Mar 02, 2005 9:53 pm
yeah mini falls apart at 5500rpm i really need a pulsar dizzy
FOR SALE MInidlx, 1293, GR head, RE-13, GR worked Redline Manifold, 45 mm DCOE,pulsar dizzy , "S" Disc's, Mk II "S" box, 3.65 diff. Minator 10X6's On the loose
PostPosted: Wed Mar 02, 2005 9:57 pm
mine goes to 5000RPM easy,gest to 5500 and says,nah not doing this crap no more..prob to do with stupid singel 1 1/2 SU that is out of tune,wont tune it again untill the weber is on 8)
BRICKWORX RACING
872-874 South Rd
Edwardstown
SA 5039
PH: 8297 9494
FAX: 8297 7133
PostPosted: Wed Mar 02, 2005 11:33 pm
HELP PLEASE
deluxe_68 wrote:
Just got hold of a D4R83 for my Mini, I know which wire goes were for the coil but this dizzy has a condenser attached to it. Do you need to use the condenser and if so how do I hook it up? (has white with black trace wire)
Cheers Pete
PostPosted: Thu Mar 03, 2005 5:59 am
That condenser is only a radio suppressor. Chuck it, it's not needed and does SFA without points. 8)
PostPosted: Thu Mar 03, 2005 8:14 am
Thanks very much for that drmini.
:D
Pete
PostPosted: Wed Mar 09, 2005 6:47 pm
I have just fitted a D4R85 to my mini but it misses when I accelerate now. Does anyone know what the problem would be? Thanks
PostPosted: Wed Mar 09, 2005 7:28 pm
Check your plug gaps- set to .035".
What coil are you using? Should be 1.5 ohm without a ballast resistor.
How are the rotor, cap & leads? Check 'em out.. :wink:
PostPosted: Wed Mar 09, 2005 7:40 pm
Thanks i will check. Does anyone know what to do about a broken vacume advance unit. I am thinking that may not be working correctly.
PostPosted: Wed Mar 09, 2005 8:00 pm
I just leave the hose off mine- I'm running a Dellorto. :wink:
Try & suck on the hose- if diaphragm is broken go buy a new vacuum can from Nissan or wherever. :wink:
