It is currently Sun Aug 24, 2025 3:58 pm
Post new topic Reply to topic  [ 8519 posts ]  Go to page Previous  1 ... 39, 40, 41, 42, 43, 44, 45 ... 568  Next
PostPosted: Mon Jun 08, 2009 8:03 pm
Didn't actualy worked on eather of them but I moved all the retaining blocks from infront of the Garage Door. I can now open the Garge door and Marcia can be warmed by the midday sun. She so lucky now 8)
PostPosted: Mon Jun 08, 2009 8:57 pm
This space for rent
Fanged it hard, on a bit of a run from Melbourne - Bendigo - Castlemaine - Melbourne 8) Didn't miss a beat, goes like a champ.
PostPosted: Mon Jun 08, 2009 9:05 pm
Put my battery on charge maybe then i'll be able to get her up on the ramps.
It might only have half the engine but its got 4 times the handling...............
PostPosted: Mon Jun 08, 2009 9:17 pm
Measured the offset of my new wheels so I can have a better look at which flares would be most suitable.
PostPosted: Mon Jun 08, 2009 9:27 pm
Motor is out, so i cleaned up the engine bay. Replaced Diff side cover oil seal and gasket. Stood in the shed looking at the engine and wondered how it makes my head hurt, then realised it might be this stinkin flu i got.
Had a chat about the work i have done and came to the conclusion that i will do it again. All learning curves and hoping for some straights.
PostPosted: Mon Jun 08, 2009 9:28 pm
Removed the engine from my Cooper S.
Fixed the headlights on one of the fleet by repairing the headlight dipper switch and fitted relays to the headlights.. All good now. then checked over the rest of the car and found the points had closed, so opened them up and then had to adjust the timing and then found the blake lights not working so had to pinch the brake light switch from the Cooper S. :(
1969 Cooper "S"
1967 Mini Deluxe
2019 MINI F55 Cooper S
PostPosted: Tue Jun 09, 2009 1:54 pm
broke the window winder trying to get it off.
then found the garage door opener motor has broken as well
PostPosted: Tue Jun 09, 2009 2:01 pm
Milatsmadmini
procrastinated from doing study, went and got a conversion cap (side to top) from karcraft for $8.50!!! then drove up and had a chat to The Man and got some of those sexy leads.... he still has a few sets left!
PostPosted: Tue Jun 09, 2009 3:26 pm
Nothing yet. Still at work :(
1969 Cooper "S"
1967 Mini Deluxe
PostPosted: Tue Jun 09, 2009 3:40 pm
pulled the dash and the windscreen wipers out trying to get them to work regularly no fun driving down the freeway in the rain and not being able to see where you are going.
PostPosted: Tue Jun 09, 2009 5:04 pm
Made some airflow :)
before | after
PostPosted: Tue Jun 09, 2009 6:29 pm
cleaned up and primed some brackets at work, dreamt on what the finished grunt will look like upon completion....smiled.....then woke up, divided the finished dream product by two, and realised I will probably have a normal looking mini! :cry:
mooo, I'm a pig!
PostPosted: Tue Jun 09, 2009 7:04 pm
Adjusted the tappets then went for a blast. Goes well with a lumpy cam and tuned properly. Just got to avoid spending money on it so i can spend money on the new project.
PostPosted: Tue Jun 09, 2009 9:56 pm
Removed the flywheel and split the engine from the gearbox, then checked the idler gear clearance and found it was none... :shock:
1969 Cooper "S"
1967 Mini Deluxe
PostPosted: Wed Jun 10, 2009 12:14 am
Tomboss Breweros
Finished filling my van with tools / parts etc then winched it backwards onto the trailer to move tomorrow.
Looked at my filthy muddy blue mini and wished i had the time to clean it :cry:
kimini wrote:
Users browsing this forum: No registered users and 208 guests
