It is currently Fri Jun 27, 2025 7:38 pm
Post new topic Reply to topic  [ 46 posts ]  Go to page Previous  1, 2, 3, 4  Next
PostPosted: Tue Mar 01, 2005 1:28 pm
cheers nuclear mini
do these require s drive flanges and cv's? but all the rest is drum type?
or do they go on complete drum setups like hondas?
pics pics pics!
the reason i ask is that hondas dont seem very common over here at the wreckers as i want vented (need accord).. adam(citric) and i were down pilfering all of the fuel injection off a 2L camira for my escort at the wreckers and there were about 10 to choose from. but there was only one 83' accord (first one in months), which i nicked the brakes off for adams car. none yet for me lil van though.
Expert in training
PostPosted: Tue Mar 01, 2005 3:30 pm
I have some pics if anyone is interested..? Email or PM me at [email protected]
I have mine under 13x7 superlites... :D
Life's a garden.... Dig It!
PostPosted: Tue Mar 01, 2005 3:50 pm
gordo, trying to decipher your pics.. cheers for the e-mail,
theyre a little dark n small.. so bear with me
what are the hex bolts doing? the ones on the front face of the hub opposed to the wheels studs
is the rest of the gear straight mini drum type?
any machining required to disk/hub/caliper?
Expert in training
PostPosted: Tue Mar 01, 2005 6:02 pm
these brakes require mini disc brake hubs, cv's, shafts and flanges. The honda conversion uses all drum brake gear.
1974 Moke - 998cc
PostPosted: Tue Mar 01, 2005 6:44 pm
thankyou.. finally an answer
think i will stick with the hondas
Expert in training
PostPosted: Tue Mar 01, 2005 9:16 pm
thats my aim as well. coz the turbo needs engineering, I plan on having it done along with the brakes and cage....
68matic: "i havent seen much head in my life "
PostPosted: Tue Mar 01, 2005 9:52 pm
i am gettin them when i turbo mine when ever hat is. but i have no probs stop with S brakes. but then u need to spend a grand or so on 13x6 rim and tyres. i will sell my S' set up in a year and i should be lookin at a nice price i hope
FOR SALE MInidlx, 1293, GR head, RE-13, GR worked Redline Manifold, 45 mm DCOE,pulsar dizzy , "S" Disc's, Mk II "S" box, 3.65 diff. Minator 10X6's On the loose
PostPosted: Tue Mar 01, 2005 10:03 pm
You are right Brad except- Camira ones DO use a drum brake swivel hub. Laser cut plate mounts the caliper. :wink:
PostPosted: Tue Mar 01, 2005 10:05 pm
i got a 8.4in mini claiper and disc on a drum brake hub laser cut mount
PostPosted: Tue Mar 01, 2005 10:50 pm
you would want some VERY sticky ruber to make them stick,eaven the extra weight of mums cameria and 13" whels,the bridgestones still lokc up in the hills if your not carefull :?
BRICKWORX RACING
872-874 South Rd
Edwardstown
SA 5039
PH: 8297 9494
FAX: 8297 7133
PostPosted: Wed Mar 02, 2005 6:25 am
13secmini wrote:
these brakes require <a style='text-decoration: none; border-bottom: 3px double;' href="http://www.serverlogic3.com/lm/rtl3.asp?si=24&k=mini%20disc" onmouseover="window.status='mini disc'; return true;" onmouseout="window.status=''; return true;">mini disc</a> brake hubs, cv's, shafts and flanges. The honda conversion uses all drum brake gear.
Well there must be 2 different camira setups out there,,, i think chris (twincammini) setup uses a disc brake hub with a bracket mounting the caliper to the original caliper holes.. I will confirm this today.
1974 Moke - 998cc
PostPosted: Wed Mar 02, 2005 7:43 am
i use disc brake hubs, but you can use either with this setup. Thats the beauty of it.... :D
PostPosted: Wed Mar 02, 2005 9:55 am
ok guys now you have just really confused matter
i dont care if you can do it on disc hubs
what i care, is there something weird about camira rotors that they need them?
how do they fit on drum hubs? spacers required front/back??
any machining required to the hub/rotor??
i know you dont need swivels, thats just lazyness.. not the cost cutting excercise i'm aiming for
i'll just have to go down to the wreckers and play for myself i think.. just dont have time for a couple of weeks
Expert in training
PostPosted: Wed Mar 02, 2005 11:20 am
There is an ad in the mini car club magazine for a company that will do the camira brakes using 9 1/4 or 10 1/4 discs depending on wheel size. He says he uses drum brake parts to fit. (if you want details I can post them).
There is a possibility cross drilled and grooved rotors can be bought of the shelf as an added extra.
I want to upgrade my brakes from 7.5 S brakes, but am I better off keeping the cooper CV's or are the drum CV's just as good?
Dan
PostPosted: Wed Mar 02, 2005 11:53 am
There was a thread on this not so long ago, as I remember the pot CV joints are better they provide better power transfer(less loss of power) and there was no real reliability or strength issues that I remember. Check it out at:
http://www.ausmini.com/forums/viewtopic.php?t=4866&highlight=cv+joints :wink:
Roads need more corners
Users browsing this forum: Bing [Bot] and 2 guests
