It is currently Sun Aug 24, 2025 1:21 pm
Post new topic Reply to topic  [ 8519 posts ]  Go to page Previous  1 ... 35, 36, 37, 38, 39, 40, 41 ... 568  Next
PostPosted: Tue Jun 02, 2009 12:49 pm
I made myself some more work by killing the left Hardy Spicer uni joint on the last run at the Wind Farm Hillclimb.
PostPosted: Tue Jun 02, 2009 2:03 pm
I dont like this thread much it gives me the guilts, today I did what I usually do, I looked at my mini sitting on the spit and thought, I am gonna get back to that
PostPosted: Tue Jun 02, 2009 2:06 pm
I had a drip from my heater onto the carpet so I pulled the heater out and now have to pull that apart to get the core out. The more things that go wrong with my car the more I love it, it just means I know more about about it and learn how to fix it! It was easy to run the hose across and bypass the heater. Anyway, thats what I am doing on my mini today.
Flute - 68 MK I Cooper S
Member: VMCI #2474
PostPosted: Tue Jun 02, 2009 7:24 pm
4myego came over and we attempted to replace the bearings in his S front hubs.
Got the drive flanges off, but no way would one CV go back through the outer bearing of the hub. Even when encouraged with a big thick brass drift and a brick hammer. Can you say `rusty'?? :x
The other hub is now fine... 2 new Timkens, NOS ball joints, new CV grease, boot and clips.
I'm now waiting for my neighbour to arrive home to attack the problem hub- he has a 20T press... :P
<EDIT> still couldn't move it with 20T and a 600C hot air gun... :evil:
BTW, all the balljoints were only finger tight, just relying on the lock washer to prevent undoing. DANGEROUS STUFF... they should be torqued up to 72ft/lb.
The PO `aeronautical engineer' should never have been let work on a car... :!:
Progress-
Well, 4myego finally got the CV out, he had to use oxy to cut the rollers out of the outer Timken. Then used angle grinder to slit the bearing inner journal off.:P
Then we found the 20T press job last night had bulged the swivel hub housing bore big in the middle.. :shock:
New swivel hub time. It's only $$$... his. :lol:
Why was old bearing so tight?
The CV shank had been gouged by a bearing before and it looks like the PO metal sprayed it to build back up. But, he left it oversize... we had to polish it down so the new bearings would fit on.
He must have used a press to assemble it.
I love fun and games...:mrgreen:
PostPosted: Tue Jun 02, 2009 7:30 pm
lost a wheel on the way to the mechanic :oops: check your wheelnuts everyone (didnt do any damage to me, the car or thankfully anyone else) then when all that fun was done got it to the mechanics and got a roadworthy which it passed, so i took it next door to work gave it a cut and polish.. now all ive gotta do is sort out rego :D
Potato
PostPosted: Tue Jun 02, 2009 7:31 pm
Nada
PostPosted: Tue Jun 02, 2009 7:41 pm
Drilled out more spotwelds, broke my drillbit, realised i didnt have another :evil: , cracked it and went inside for a coffee. trip to totaltools 2morrow, think i will buy a stash ov em
PostPosted: Tue Jun 02, 2009 8:15 pm
My super dooper strong magnets for the oil filter arrived today :mrgreen:
Now to work out how to get them apart :roll:
David L
PostPosted: Tue Jun 02, 2009 8:20 pm
Didnt they put a plastic spacer between them :roll: Chisel.
Did they post them in a metal box also or just in bubble rap :roll:
Pry em apart with a broken drillbit, i can give you one :lol: :lol:
PostPosted: Tue Jun 02, 2009 9:03 pm
Zip, zero, zilch, nothing . . . did wallk past it though . . .one day.
Dave K.
 Post subject: 1275LS
PostPosted: Tue Jun 02, 2009 9:48 pm
Removed all of the parts from the front subframe. Subframe looks a bit damaged from accident and too many wrongly placed car jacks so uncoverd spare subframe from my pile of spare parts and started to clean it up. Old front subframe will now be scrapped. Also removed steering rack, steering column and pedals. Most parts almost stripped from the shell, so shell will soon be ready for sandblasting and replacement of rusty parts. Also need to sand blast subframes, remove dings and paint.
1969 Cooper "S"
1967 Mini Deluxe
2019 MINI F55 Cooper S
PostPosted: Tue Jun 02, 2009 11:46 pm
Tomboss Breweros
Re blingd my wheels and custom centres ready for Hay 8)
kimini wrote:
Jimmyinamini wrote:
PostPosted: Wed Jun 03, 2009 10:32 am
I spent more money on it, this time I brought a BMW mini supercharger for it.
Lindsay Palmer
06 Mazda SP23
80 Alfa GTV (weekend toy)
86 626 Turbo (daily drive, now stolen)
71 cooper s replica
69 cooper replica
76 clubman
62 english 850
68 Mini Auto
PostPosted: Wed Jun 03, 2009 12:40 pm
Took my Mk1 type metal heater apart today to get the leaking core out. It looks like its had it. Have to look at the mini sites now to see if I can get a new one.
Member: VMCI #2474
Users browsing this forum: acarseldine and 108 guests
