It is currently Fri Jun 27, 2025 6:53 am
Post new topic Reply to topic  [ 50 posts ]  Go to page Previous  1, 2, 3, 4
PostPosted: Tue Mar 01, 2005 6:03 pm
Yea, I've sized the perfect 'cooler for a clubbie.... (Or a Moke?)
Sierra Cosworth..Long, thin and narrow.... good enough for 400Hp...excellent)
I'll keep experimenting... 2 and a bit years on its still going without one, so.........
J
PostPosted: Tue Mar 01, 2005 9:24 pm
I think with our setups Kaxjim, we might be able to run a front mount up underneath the bonnet and do it like the cover car from the miniworld magazine....
I hope at least....
68matic: "i havent seen much head in my life "
PostPosted: Tue Mar 01, 2005 9:56 pm
run a thin intercooler and use it like a grill. and if your into ricers it will make it even cooler
PostPosted: Tue Mar 01, 2005 10:17 pm
buy the sounds,a cooler isnt realy NEEDED,would just be good to have for when the boost gets wound up a bit.maby radiator in the boot,inter cooler in place or radiator with a mini fan pulling air thru it :D
BRICKWORX RACING
872-874 South Rd
Edwardstown
SA 5039
PH: 8297 9494
FAX: 8297 7133
PostPosted: Wed Mar 02, 2005 7:48 am
they arent NEEDED, but are a damn good idea when you are trying for big power. 8)
I plan on running a front mount up underneath the top of my bonnet if I can figure it out... But for the time being i just wanna get it on the road....
Users browsing this forum: No registered users and 21 guests
