It is currently Sat Aug 23, 2025 7:34 pm
Post new topic Reply to topic  [ 8519 posts ]  Go to page Previous  1 ... 27, 28, 29, 30, 31, 32, 33 ... 568  Next
PostPosted: Sat May 23, 2009 5:48 pm
talked lots about it, then prepared to do some major cutting out in the boot, then relatives arrived.
No work done again!
mooo, I'm a pig!
PostPosted: Sat May 23, 2009 6:15 pm
Refitted my Speedo to my Cooper S after getting rebuilt!
and washed my MINI COOPER S (BINI)
PostPosted: Sat May 23, 2009 7:09 pm
Removed the front stone tray, threw over left shoulder, will the rust ever stop? But air chisels are lotsa fun :lol:
PostPosted: Sat May 23, 2009 7:40 pm
Adjusted the passenger side wheel bearing. It had a little spot of movement so I linished the spacer down a few thousandths of an inch and refitted.
PostPosted: Sat May 23, 2009 8:07 pm
took my carbs and extractors off last night, welded a bung for an O2 sensor into the extractor collector, ran the wiring for the megajolt & EDIS coil
put everything back together today, added a vacuum line for each carb back to the megajolt, ran some wires for the O2 sensor and fitted that. Then connected all the megajolt up and connected it to my computer, ran the engine off the normal dizzy and the rpm and vacuum readings displayed in the megajolt software. So then I made a bracket for the EDIS coil and mounted it, connected all the wires up and tried to start the engine - it didn't go, but then I realised I hadn't connected the VR sensor, connected that and it started first go :shock:
I've got a motorkhana tomorrow, so I need to decide whether to put the normal ignition back in place for tomorrow, or run with the megajolt and take the normal ignition just in case
PostPosted: Sat May 23, 2009 8:50 pm
Fitted a new dust cover to the knuckle joint then fitted the left swing arm. Got the front sub frame 9/10ths installed - one of the floor bolts is giving me some grief. Fitted the cowel on the steering column and found the indicators wouldn't turn on for right turn - then wouldn't self cancel so had to fiddle with the setup again and get it all working again. Found I had only treated the rust in the fuel tank all those years ago and hadn't painted the insides - found it rusty inside again so gave it a rust treatment again and will paint it this time :roll: Painted the radiator support bracket.
David L
PostPosted: Sat May 23, 2009 8:51 pm
Overhauled the clutch master cylinder on the grey mini so I could drive it under the carport and out of the rain.
67 Deluxe - Red and white
69 Deluxe - Sugercane Grey
PostPosted: Sat May 23, 2009 8:53 pm
a good day for the mini today.
Took the engine out for the first time only took me and, mainly dad 1 hr to get it out, took out the steering rack and also replaced the primary gear seal, so glad we had a flywheel puller those buggers are tough to get off.
tommorow is painting the engine and engine bay and putting her all back together
I'm grew up on the street, not the hood, the sesame st
PostPosted: Sat May 23, 2009 9:48 pm
Only colour coded two wire diagrams. One for the Mains the other for lights
PostPosted: Sat May 23, 2009 10:54 pm
Finally got around to replacing the wiper wheel boxes - well almost - was just refitting in the fading light when i found out that the replacements were too short for the nut to catch the thread.
So put it on hold as it was dark, cut the spacers down by a couple of mm tonight, will re-assemble in the morning.
PostPosted: Sun May 24, 2009 12:04 pm
Tomboss Breweros
Yesterday, i took it into work, wahsed it and fitted the pinstripes and my username stickers. Not sure bout the paint finish :?
kimini wrote:
Jimmyinamini wrote:
PostPosted: Sun May 24, 2009 3:02 pm
Tombo you need a little Australian flag after it just like race car drivers :lol:
PostPosted: Sun May 24, 2009 4:41 pm
Cut rear hinge panel off boot, cut out rusty sections,had can of cougar, rust treated the floor so as to be sure, fitted repair panels to both sides of boot floor,had can of cougar, tacked in place, looked at it, squinted eyes while looking at it, had can of cougar, "shut up mongrel dog!", scratched a bit, forgot what I was doing, had can of cougar, squinted eyes while looking at boot floor, "sheel be right" I says.
All this while the wife scraped away at the engine bay removing 45 years of dirt, mud, grime and tar. She's a top chick!
mooo, I'm a pig!
PostPosted: Sun May 24, 2009 4:42 pm
I've went to take mine for a drive, found it had a flat battery so I am currently rechrging it!! GRRRR Bloody mini!! Ohh and I gave it a wash!
PostPosted: Sun May 24, 2009 5:46 pm
Gave it a wash and took it to a car show at Medowie.
Users browsing this forum: AWOODY, winabbey and 262 guests
