It is currently Sat Aug 23, 2025 7:31 pm
Post new topic Reply to topic  [ 8519 posts ]  Go to page Previous  1 ... 26, 27, 28, 29, 30, 31, 32 ... 568  Next
PostPosted: Wed May 20, 2009 6:30 pm
got my number plate light working, made a bracket to stop the fuel filter from shaking too much, got my wipers working.. painted the wiper motor, screwed my wheel well carpet pieces into place and got the rest of the carpet sitting nice then refitted the dash and switches and ran some finishing strips along both sills and the rear bins... roadworthy next week or the week after.. cant wait!
Potato
PostPosted: Wed May 20, 2009 6:38 pm
Yer a machine!!
PostPosted: Wed May 20, 2009 8:45 pm
Removed the rear brakes and shockers in preparation to remove the rear subframe tommorrow night.
1969 Cooper "S"
1967 Mini Deluxe
2019 MINI F55 Cooper S
PostPosted: Wed May 20, 2009 9:05 pm
removed both hardy spicer uni joints, get new ones tomoz
100% Pure A Series Turbo
PostPosted: Wed May 20, 2009 9:21 pm
Tried to fit my new harmonic balancer, but it's too tight - won't fit :cry:
PostPosted: Fri May 22, 2009 8:48 pm
Dried out the inside passenger floor after all the rain we have had on the Gold Coast. Booked in to have the windscreen popped out re-sealed and put back in tomorrow morning.
PostPosted: Fri May 22, 2009 8:49 pm
Nothing again,,, just drove it to the shops & down to the machine shop & took my puppies up to the vet :-)
PostPosted: Fri May 22, 2009 9:10 pm
Nice bump :wink:
did a bit more on my spagetti :lol:
Give you a pic tomorrow :wink:
PostPosted: Fri May 22, 2009 9:15 pm
Found the radiator support bracket and I wasn't even looking for it at the time 8)
David L
PostPosted: Fri May 22, 2009 9:23 pm
Looked at it, poked it with something sharp, found more rust, poked it again, found filler an more rust. But i still luv her :D
PostPosted: Sat May 23, 2009 1:03 am
Tomboss Breweros
Poking is good :wink:
I polished the roof from 2000 paper finish to a high gloss 8)
Put the battery and spare tyre back in.
Mounted the carbon cannister, and thanks to Garreth in radelaide i know it's in the right place.
kimini wrote:
Jimmyinamini wrote:
PostPosted: Sat May 23, 2009 8:44 am
I will be preping garage for sandblasting. :)
PostPosted: Sat May 23, 2009 9:12 am
Borrowed Drmini's special tool and undid the casellated nuts on the disc brake cvjoints and took the driveshafts off - I had removed the brakes from the car before I had undone the nut.
Fitted the brake hoses unto the drum brakes back on the car, and filled it with fluid. One hose still needs nipping up, a quick check then bleed the brakes. Lucky the engine's out. I'd hate to have to do that with it in.
KB
PostPosted: Sat May 23, 2009 4:25 pm
Swapped 4myego's rockers in the 1360S from fresh Toyota Corollas (1.46:1) to fresh offset bushed pressed steel ones (1.3:1).
More torque, less top end, for the way he'll drive it. 8)
PostPosted: Sat May 23, 2009 5:05 pm
Stripped the Dash....
The Pedal Box came out in 2 pieces....
Have I tempted fate from Lord Lucas?
Did a bit of cleaning in the Engine Bay.
Dicko
Users browsing this forum: AWOODY and 304 guests
