It is currently Sat Aug 23, 2025 7:44 pm
Post new topic Reply to topic  [ 8519 posts ]  Go to page Previous  1 ... 25, 26, 27, 28, 29, 30, 31 ... 568  Next
PostPosted: Tue May 19, 2009 1:15 pm
Yes. You deserved it for driving an XTrail :P
I removed my knackered harmonic balancer last night.
Not only is the keyway flogged, the rubber is stuffed too!
PostPosted: Tue May 19, 2009 1:56 pm
Un picked LHF Guard & cleaned all seams a spot points. YAY iv finally started :D
PostPosted: Tue May 19, 2009 3:32 pm
Set out to clean up gutter rash and polish some wheels for a bloke, found the bastards are clearcoated... :x
PostPosted: Tue May 19, 2009 4:21 pm
Minis are off the menu. MOKE time. repairing the buchered job someone did trying to remove the side panel to get the fuel tank out. They did not look under- neath to see that there was a panel that unbolted to remove it :x :x :x
www.minisprintgt.com
PostPosted: Tue May 19, 2009 7:57 pm
Picked apart loom, Seperated and put into groups, Cleaned and taged all area's that have been sorted :lol:
PostPosted: Tue May 19, 2009 8:46 pm
Picked up my 2 speedos!! from otto Instruments in Brisbane, They look fab!
PostPosted: Tue May 19, 2009 9:27 pm
Nothing tonight! :(
Worked late.
Last night I checked out how the body kit might fit and decided all of the stories and comments are sadly true.
Looks like a major project just to fit the body kit after all of the rust and dents are fixed and the new front guards have been fitted.
1969 Cooper "S"
1967 Mini Deluxe
2019 MINI F55 Cooper S
PostPosted: Tue May 19, 2009 9:29 pm
Took a photo of the Weber for Ryan. Too cold to stay in the garage any longer.
PostPosted: Tue May 19, 2009 9:31 pm
Too cold to stay in Canberra at this time of year.
1969 Cooper "S"
1967 Mini Deluxe
PostPosted: Tue May 19, 2009 9:51 pm
Pulled a HIF44 down to build it up for Scrapper2's motor. Which will go on the engine dyno just after hay. Looking forward to seeing where it comes up.
PostPosted: Tue May 19, 2009 11:04 pm
Tomboss Breweros
Got some carpet, cut it to fit the boot floor all the way up the boot lid. Then took it back to the supplier to have the edge stitched. 8)
kimini wrote:
Jimmyinamini wrote:
PostPosted: Wed May 20, 2009 9:59 am
Picked up my new cage and assembled it...
Miniworx Centre 0883741299
Online BMW Mini Shop
PostPosted: Wed May 20, 2009 10:01 am
But you didn't assemble it IN the car! Now you'll have to do it again!
:D
PostPosted: Wed May 20, 2009 10:04 am
I had to assemble it on the ground to know where all the bits went.
some pieces look the same left to right but don't fit.
And there isn't enough room in the car to muck around.
It has been in the car once before...
PostPosted: Wed May 20, 2009 6:24 pm
number 3 daughter (13y.o) chasin tim worm and makin sparks!
going sick with an air chizel.. fun!
Users browsing this forum: No registered users and 28 guests
