It is currently Thu Jul 17, 2025 9:33 pm
Post new topic Reply to topic  [ 8519 posts ]  Go to page Previous  1 ... 23, 24, 25, 26, 27, 28, 29 ... 568  Next
PostPosted: Sat May 16, 2009 7:55 pm
Actually have something to report for the first time since this thread started (apart from driving it or glancing at the car as i walked to/from the station)
Today I started to try to fix my wipers, which have never really worked properly since I've had the car. My first attempt last year got as far as replacing the motor but although it helped a little, it didn't solve the problem.
Got started late (mid-arvo) and then inbetween bouts of gastro/running to the toilet and taking care of our 10 month-old munchkin, removed the bonnet, got the wiper motor & cable-thingy out, degreased and cleaned up the thingy, stuck pipe cleaners into the channel to see how mucky it was (not bad) and considered removing the wheelboxes.
Then realised that I didn't know where i'd put the new wheelboxes that I got ages ago, so decided not to go any further until they had been found. Hopefully fine them tomorrow and do the wheelbxes -
I hate how the f-ing Haynes manual says, (along the lines of 'simply remove the two bolts.... blah blah blah' then has this diagram of the wheelboxes right underneath the window, innaccessible to all but the most dextrous and/or small fingers...there's never a trained monkey or 8-year-old slave child on hand when you need one, is there??
PostPosted: Sat May 16, 2009 11:53 pm
Tomboss Breweros
I removed my fingerprints by sanding the paint on the roof, now i need more 1200 paper to carry on tomorrow.
My clubby now has more room in the shed due to me throwing out old paint tins and collections of unused stuff.
kimini wrote:
Jimmyinamini wrote:
PostPosted: Sat May 16, 2009 11:56 pm
Tomboss Breweros
willy wrote:
[quote=TOMBO]I removed my fingerprints by sanding the paint on the roof, now i need more 1200 paper to carry on tomorrow.
My clubby now has more room in the shed due to me throwing out old paint tins and collections of unused stuff.[/quote]
Sorry :oops: Image
kimini wrote:
Jimmyinamini wrote:
PostPosted: Sun May 17, 2009 8:05 am
going to RACV Classic display Flemington :) :)
PostPosted: Sun May 17, 2009 4:09 pm
Repinned and rebushed 4 door hinges for Brad (13secmini).
Geez I hate people who drill out door hinges and fit dodgy homemade oversize `bit of a bolt' bushes..... lucky only 1 was like this. :lol:
PostPosted: Sun May 17, 2009 5:06 pm
fitted my pretty coloured engine today, extractors were a pain in the ass to fit but all done
PostPosted: Sun May 17, 2009 5:14 pm
"cained" it all the way to the RACV classic, waited all day, then "cained" it all the way home :D
PostPosted: Sun May 17, 2009 5:26 pm
nudda
PostPosted: Sun May 17, 2009 6:39 pm
Installed the steering rack - what a PITA that is. Easy getting it out - lot harder getting it back. Now what have I done with the chome bolt that holds the column to the dash bracket :?
David L
PostPosted: Sun May 17, 2009 6:51 pm
Took the rear windscreen out - Keys were at house 1, car was at house 2 and i needed the glue, and screwdriver in the rear seat!
PostPosted: Sun May 17, 2009 6:59 pm
blokeinamoke wrote:
mickmini wrote:
drove it to work and back in the rain with Paul Kelly on the CD :roll:
He must have been cramped :P
well he is pretty slight :lol:
PostPosted: Sun May 17, 2009 7:03 pm
ReFitted Morris Rear arch's and also re hooked up the heater.
Morris well here's what I'v ben up to
http://www.ausmini.com/forums/viewtopic ... 113#636113
PostPosted: Sun May 17, 2009 8:30 pm
removed the engine
1969 Cooper "S"
1967 Mini Deluxe
2019 MINI F55 Cooper S
PostPosted: Sun May 17, 2009 9:18 pm
took the donk out of my grunt (after making a goose out of myself asking about block removal while still in the car :oops: )
Then went for a drive and picked up another donk to eventually drop in from a top bloke!
mooo, I'm a pig!
PostPosted: Sun May 17, 2009 11:14 pm
did the reverse of yesterday - put the harmonic balancer and trigger wheel on, made a nice bracket for the VR sensor and put the radiator etc. all back together so I can drive to work tomorrow!
