It is currently Fri Aug 22, 2025 6:11 am
Post new topic Reply to topic  [ 8519 posts ]  Go to page Previous  1 ... 4, 5, 6, 7, 8, 9, 10 ... 568  Next
PostPosted: Sun Apr 26, 2009 8:20 pm
Zip
PostPosted: Sun Apr 26, 2009 8:50 pm
Bought a fan belt, tried to find an adapter for the Speco Temp gauge probe and got blank looks fron Supercheap bird and Ripco kid.
David L
PostPosted: Sun Apr 26, 2009 8:51 pm
well I was going to do a motorkhana, but it the weather was rotten yesterday, so we cancelled the khana - the ground would have been sodden today, but the weather wasn't too bad
PostPosted: Sun Apr 26, 2009 8:52 pm
yeah, good luck.... try Pirtek
PostPosted: Sun Apr 26, 2009 9:11 pm
Stripped the under carriage back to bare metal. Found some more holes in the passenger side floor :(
PostPosted: Sun Apr 26, 2009 9:31 pm
Put the distributor back in. Checked out the firing order and made sure the leads connected to the correct plugs.
Question: Graham R told me to change the plugs. I have BP6ES and I think because of the higher compression it would have to be BP7ES (colder).
Dave K.
PostPosted: Sun Apr 26, 2009 9:38 pm
Spent all weekend putting in a SPI motor, fired up first kick :)
But the water pump is leaking :( so out with radiator and put another one in.
Cheers Pete
PostPosted: Sun Apr 26, 2009 9:44 pm
Cheers Pete
spuing .
PostPosted: Sun Apr 26, 2009 9:56 pm
All I did was washed it today. 8)
PostPosted: Sun Apr 26, 2009 10:02 pm
Took it for a run out to Armadale, then broke the clutch on the way back :cry:
Had to baby it through the last three roundabouts. clutch wouldn't disengage, but would also slip if given more than 1/5th throttle. Add one more job to the list :roll:
PostPosted: Sun Apr 26, 2009 10:09 pm
I washed mine today. Driving in torrential rain!!
I also found out what it's like to have water running in through the slide window channels.
Mmmmm wet door pockets with camera, phone, wallet and Melways :x
Image Image
PostPosted: Sun Apr 26, 2009 11:10 pm
:arrow: picked up my new motor, which will become the new turbo motor for my delux!
and worked on my car trailer, getting it ready for hay!
-jamie-
1963morris 850
1965 solid side van
1994 rover racecar
PostPosted: Sun Apr 26, 2009 11:35 pm
ginger ninja
ginger ninja
m
ahh been there, done that. All part of the joy of owning a mini
sports850 wrote:
PostPosted: Sun Apr 26, 2009 11:36 pm
i primed and put another guide coat on
PostPosted: Mon Apr 27, 2009 4:05 pm
The TIG
I worked on Traveller number 2. I did some cleaning of the engine, and some electrical connections. I installed a new ignition switch so I can started with a key instead of hot wiring it. And I fixed enough connections so that I can now properly install a battery and get power to the car. More tomorrow.
email - [email protected]
www.victoria-chiropractors.ca
Users browsing this forum: No registered users and 291 guests
