It is currently Thu Jul 03, 2025 12:03 pm
Post new topic Reply to topic  [ 8519 posts ]  Go to page 1, 2, 3, 4, 5 ... 568  Next
PostPosted: Wed Apr 22, 2009 11:06 pm
Hopefully this will continue onto being a long-running thread.
Stolen from another forum.
Pics are ok - limit them to one or two if you can, and keep them at a usable forum size (800x600).
SO.... What did you do on your Mini today?
Today I bought some new fuel line, new Facet competition fuel pump, and did a small rust replacement on the rear floor (panel that the rear seat cushion sits on).
PostPosted: Wed Apr 22, 2009 11:15 pm
Nothing on mine........but I made 1 blokes run, stop and steer much, much better! :D Another one had the engine painted red! so it will go 10% faster of course :wink:
PostPosted: Wed Apr 22, 2009 11:16 pm
High heel ninja
Graham Russell milled one of his manifolds for me, as im having trouble fitting my HIF44 carb & manifold into my MK2 Cooper S, after getting it milled i refitted it to the car, still no luck, manifold won't seal onto the manifold gasket.
Looks like it gunna have to trim some metal out of the firewall :shock:
Doogie
PostPosted: Wed Apr 22, 2009 11:19 pm
bought a new water pump.. cast impellor! :D
tim
PostPosted: Wed Apr 22, 2009 11:26 pm
I reamed out my trailing arm bushes.
PostPosted: Wed Apr 22, 2009 11:40 pm
havent done anything since the last holidays, and wont be doing anything till the next one. ie june :(
PostPosted: Wed Apr 22, 2009 11:52 pm
I thought about what I need to do to get in going for the Cruise to the Qld Mini Muster. Does that count?
Dicko
PostPosted: Wed Apr 22, 2009 11:54 pm
flogged the crap out of mine coz the new motor is about to be finished
PostPosted: Thu Apr 23, 2009 12:29 am
severely reduced the power-to-weight ratio of my Moke- refitted the sump guard.........
in readiness for a Deua National Park adventure. :)
PostPosted: Thu Apr 23, 2009 12:42 am
had a new alarm system fitted take that Theives
PostPosted: Thu Apr 23, 2009 7:23 am
i brought parts from the mini king!!!!
with the stimulus package :twisted:
'94 Honda EG4 Civic. -Daily-
'95 Honda DC2 Integra
PostPosted: Thu Apr 23, 2009 7:32 am
- Removed front hubs and greased the bearings
- Painted and replaced the brake backing plates
- Installed new twin wheel cylinders on each side
- Re-shimed the top and bottom ball joints on both sides
- Drilled out a broken grease nipple, re-threaded and replace nipple in hub
- Connected new brake hoses on both sides on the front
- Replaced new brake line that runs around front of the front subframe
- Bolted new engine mounts to engine (ready to put in)
Dave K.
PostPosted: Thu Apr 23, 2009 7:36 am
bout to pull out my radiator casue it is no good :( not looking forward to it
PostPosted: Thu Apr 23, 2009 7:50 am
I chased some electrical faults and cleaned up the wiring a bit in spots.
Then took it for a drive.
Matt
PostPosted: Thu Apr 23, 2009 7:57 am
Yesturday I back to Blinging the 48 Dellorto :roll: why did I start it in the first place :twisted:
Users browsing this forum: No registered users and 72 guests
