It is currently Wed Jun 25, 2025 8:13 pm
Post new topic Reply to topic  [ 21 posts ]  Go to page Previous  1, 2
PostPosted: Thu Apr 16, 2009 1:15 am
i probably asked this before.. but how much would that Powertec reversing differential cost?? sounds like the ideal solution to make the mini road worthy. Also... I wonder how much hp it can handle..
PostPosted: Thu Apr 16, 2009 9:34 am
Hey Pud,,, Quaife do one as well
http://www.quaife.co.uk/Quaife-Rage-Motorsport-reversing-differential-unit-includes-reverse
PostPosted: Thu Apr 16, 2009 11:49 am
Just to add to the engineering convo...
My engineer, from a very large company quoted me around $2450 for the approval plus track testing. He'll write up all the documents and do the formalities for me I just have to finish the work to his standard and take the car to the RTA when it's done.
I started the process off after the engine was already in the car etc. He said he prefers you to speak to him BEFORE you start the build as you need to prove to him that its a good idea and buildable safely. Either way though he said he has approved many already finished cars but has at the smae time come across cars that was required welding and body mods after a nice paint job, so beware.
For racing only then as above 1.3 turbo is not the best option. Motorbike sounds like the most fun. Maybe a Range Rover 4.6 V8!?! nah too big but wouldn't that be fun.... Oh and definitely midmounted!
PostPosted: Thu Apr 16, 2009 4:16 pm
Mokesta wrote:
greyghost wrote:
...and its not even that expensive, last engineers approval cost me $200, for an inspection of the car before i started. where we talked ideas for a couple of hours. i didn't cost anything when he came round and a visited 1/2 build, to an update and approve the changes, i wanted over the original build spec.
WOW, you won't find many engineers that cheap! The risk and liability are too much for that little pay. Maybe one-man-band engineers are brave and under-paid but a larger consulting engineering company wouldn't charge less than $150 per hour for someone sufficiently qualified. (the eng gets paid 1/3 of that though...) So, he drove both ways, twice, spent a couple of hours the first time and maybe 1/2 hour second time:
assuming 1/4 hour travel time, 1 hour to do all the paperwork including tax invoice etc. You've got 4.5 hours. So your bloke charged $45 per hour and didn't even have time to do any check calculations to see if it was all OK. :shock: :shock:
I think I once worked out that to get one of the guys at my work to do a proper job of a sub-frame assessment and approval, one that would survive professional scrutiny, it would cost at least $15,000. That doesn't include any construction, just the check. Once he'd done a few he could use a comparitive technique that could cut the cost down to maybe $5k each time....
M
that was the first inspection. the final inspection was about $1000, and this didn't include the cost of X-ray. i did all the Fab work myself to his specs, it will all depend on what is being changed and by how much.
this project was not a Jap engined mini. it was something else.
PostPosted: Thu Apr 16, 2009 8:32 pm
TheMiniMan wrote:
Oh,,, i though he was talking about a road registered race mini
But if he was only after a hillclimb special,,,, wellllllllllllllllllllllllll :-)
the obvious answer is Bike engine,,, rear/mid mount,,, light as possible,,,, barest of essentials,,, & then simply remove the brain & add it to the balls ,,, lower center of gravity you see :-) & apply copious amounts of the right peddle
or maybe fit one of these--->
http://www.powertecengineering.com/
or one of these--->
or any of the other "umpteen" similar designs of lightweight motorbike engine based weapons avaliable if you`re filthy rich
anyone buy a lotto ticket today??????????
Yep, that's what I'm talking about!! :D
Having raced SR3 Radicals, I can tell you they are awesome fun!!
And a Mini wouldnt be that far behind either. :shock:
Definitely mid-mount, definitely RWD, and definitely bike engined!
Matt, I think the Taggart (TRE) rear diff would be a goer here!
PostPosted: Fri Apr 17, 2009 1:33 am
I agree Tricky,,,
