It is currently Fri Jun 27, 2025 8:14 am
Post new topic Reply to topic  [ 40 posts ]  Go to page Previous  1, 2, 3  Next
PostPosted: Thu Feb 24, 2005 11:06 am
yeah but is it rod or remote?
BRICKWORX RACING
872-874 South Rd
Edwardstown
SA 5039
PH: 8297 9494
FAX: 8297 7133
PostPosted: Thu Feb 24, 2005 11:29 am
pretty sure its rod. is this just when the shift has been moved to your feet and not the old magic wand? or is it internal? i probably should know but im pretty sure its rod...
PostPosted: Thu Feb 24, 2005 12:09 pm
say again?
BRICKWORX RACING
872-874 South Rd
Edwardstown
SA 5039
PH: 8297 9494
FAX: 8297 7133
PostPosted: Thu Feb 24, 2005 12:19 pm
The remote shift has an aluminium casing which comes back from the gearbox to the place where the gear stick enters the cabin.
The Rod change has two rods that come off the gear box back to where the gear shift enters the cabin they then enter a rectangular box the top of which holds the gear stick.
A magic wand is a gear shift that enters the cabin at about the base of the firewall and is a really long stick
The rod change gearbox you have to lift the gear stick up to select reverse.
Hope this helps
Roads need more corners
PostPosted: Thu Feb 24, 2005 1:32 pm
:shock: THAT IS THE BIGGEST DIFF PIN I'VE EVER SEEN!!!:shock:
look at it... it's as big as the car!!!!
:wink:
PostPosted: Thu Feb 24, 2005 1:55 pm
then it'll be remote, got the casing going back to the shift. i was thinking about a quickshift kit. would this be a good invest ment or not?
PostPosted: Thu Feb 24, 2005 4:45 pm
Isn't the remote a quick enough shift for ya :lol: A good remote box should be pretty tight, i wouldn't waste the money on a quickshift for it ;)
PostPosted: Thu Feb 24, 2005 6:38 pm
They are not really a `quickshift' but a `shortshift'. Remote box is pretty short throws to start with. I wouldn't want mine any shorter... :lol:
To make it even better, just overhaul the linkage to remove any slack.
PostPosted: Thu Feb 24, 2005 9:41 pm
hey,
i took my car for its first drive on the road on wed's,DAMN i couldnt get gears,its tighter than all the crusty rod boxes im use to driving.i would still like a KAD short shift..
My rebuild remote box is tighter than big willies rod box with short shifter :lol:
BRICKWORX RACING
872-874 South Rd
Edwardstown
SA 5039
PH: 8297 9494
FAX: 8297 7133
PostPosted: Thu Feb 24, 2005 9:51 pm
yeah i was surprised at how tight the gears are with the new motor i just thought a quickshift would make the changes sweeter and 2nd to 3rd like all new cars where it just flicks in.
PostPosted: Thu Feb 24, 2005 9:55 pm
yeah i thinkit may make it alittle to tricky.
i remember driving a hottie 1100 with a KAD quick shift in a remote box,i was a nitemare for the first fue streets,but once ya got the hand of it,WOW you could realy pull them gears thru at a quick rate,almost sounded like a auto :D
or do a bit of warren/willie style and shift with no clutch :P
BRICKWORX RACING
872-874 South Rd
Edwardstown
SA 5039
PH: 8297 9494
FAX: 8297 7133
PostPosted: Thu Feb 24, 2005 9:57 pm
YES! No clutch.
If you wanna learn to drive without a clutch...
See WARREN! :)
PostPosted: Thu Feb 24, 2005 10:03 pm
yeah its fun stuff,its eaven better when your mate goes,ill go one batter,ut his left foot on the dash,goes for 4th and crunches the F()ck out of the gearbox :lol:
BRICKWORX RACING
872-874 South Rd
Edwardstown
SA 5039
PH: 8297 9494
FAX: 8297 7133
PostPosted: Thu Feb 24, 2005 10:08 pm
:) Then continues pulling on the selector so it crunches some more.
:lol: - Doesn't matter; its only mums car :lol:
PostPosted: Thu Feb 24, 2005 10:39 pm
LUV IT.
there should be more of it and
FUDD take please its cutting out mega big time :lol:
BRICKWORX RACING
872-874 South Rd
Edwardstown
SA 5039
PH: 8297 9494
FAX: 8297 7133
