It is currently Sun Jun 22, 2025 12:06 am
Post new topic Reply to topic  [ 377 posts ]  Go to page Previous  1 ... 9, 10, 11, 12, 13, 14, 15 ... 26  Next
PostPosted: Wed Feb 23, 2005 9:34 pm
CLUBMAN wrote:
so you have to hit the key,get it spinning then flick the switch and give the ignition power?spunds like a pritty cool idear to stop people stealing your car
Yep that's a side benefit. Along with a few other `immobilizers'... 8)
BTW I use a toggle switch as it's cooler than a push-pull. :wink:
You could go for one of those covered ones where you have to flick the cover up to flick the switch and send the missiles off to kill the baddies.....that's Mini, Dr Mini, 007! :lol:
PostPosted: Wed Feb 23, 2005 9:39 pm
Ohh i want:
:mrgreen:
PostPosted: Thu Feb 24, 2005 12:49 am
One of those switches with the word IGNITE in big letters under it.
Yeah yeah.
They're 12 bucks :wink:
On another note..... what if you had the ignition rigged so that when the starter motor is powered, there is no power going to the coil. It should kick over fine once you release the key, yes? Image
PostPosted: Thu Feb 24, 2005 6:09 am
No... you need it to spin, as the flywheel on any Mini is pretty light (unless it's a !*^#&$ Verto one..) :lol:
PostPosted: Thu Feb 24, 2005 9:06 am
Trouble is i would keep forgetting to turn the bloody power on,then flattern my battery while swearing my head off at it :P ,
i might hook the fuel pump up with the ignition so there will be NO GO if that switch isnt on :lol:
THAAAAAAAAAAAAAAAAAAAANK DOC!
BRICKWORX RACING
872-874 South Rd
Edwardstown
SA 5039
PH: 8297 9494
FAX: 8297 7133
PostPosted: Thu Feb 24, 2005 9:38 am
Or maybe Carve out the Gear stick, fir a little red butting with the words "DONT GO BABY DONT GO"
Sorry, was kinda lame, i know.......
J
PostPosted: Thu Feb 24, 2005 10:51 am
putting one to the fuel pump is a good idea then hide the swicth. then if it gets nicked they won't be able to take it a 150 mile joy ride like what happen to mine
FOR SALE MInidlx, 1293, GR head, RE-13, GR worked Redline Manifold, 45 mm DCOE,pulsar dizzy , "S" Disc's, Mk II "S" box, 3.65 diff. Minator 10X6's On the loose
PostPosted: Thu Feb 24, 2005 12:13 pm
idlike to wire the fuel pump and the ignition to a switch,so no spark and no fuel,so if they did happen to give the dizzy power it wouldnt go very far :D
BRICKWORX RACING
872-874 South Rd
Edwardstown
SA 5039
PH: 8297 9494
FAX: 8297 7133
PostPosted: Thu Feb 24, 2005 9:12 pm
We fitted a kill switch to a car and didn't have to fit a switch. The car had a sliding ashtray and when it was pushed right in the ignition was earthed out. Had a few people push it in while driving, but it was effective, quick to use and not obvious.
Chris
Everything I like is either
PostPosted: Thu Feb 24, 2005 9:18 pm
GEEEEEEEEEZ im not that technical,i was thinking of just a togle on the dash with HAZZARDS written under it :D
BRICKWORX RACING
872-874 South Rd
Edwardstown
SA 5039
PH: 8297 9494
FAX: 8297 7133
PostPosted: Thu Feb 24, 2005 9:23 pm
I DWIVE A BIG TWUCK
I DWIVE A BIG TWUCK
my old man when he was alive bought a funky little kill swith you neede a magnet placed over it to start it :)
makka
PostPosted: Thu Feb 24, 2005 9:29 pm
Magnetic Reed Switch.
Cost bugger all and a very good type of switch as you can hide it way better. Eg... in the hoodlining would be a good place to have it :wink:
PostPosted: Thu Feb 24, 2005 9:32 pm
yshould have told me this B4 i got my new roof lining out in :(
BRICKWORX RACING
872-874 South Rd
Edwardstown
SA 5039
PH: 8297 9494
FAX: 8297 7133
PostPosted: Wed Mar 02, 2005 7:51 pm
Just got hold of a D4R83 for my Mini, I know which wire goes were for the coil but this dizzy has a condenser attached to it. Do you need to use the condenser and if so how do I hook it up? (has white with black trace wire)
Cheers Pete
PostPosted: Wed Mar 02, 2005 8:45 pm
what difference or advantage does an electric or pusar or whatever dissy have over standard?
