It is currently Wed Jun 25, 2025 6:54 am
Post new topic Reply to topic  [ 37 posts ]  Go to page Previous  1, 2, 3
PostPosted: Sun Mar 01, 2009 12:08 am
i
The program is "Rhino 3D ver3.0"
im about 90% sure how diffusers work
the ratio of inlet to outlet is still to be decided
im still redesigning the rear floor pan and a retub of the rear wells At the moment
if you know of any good sites on diffusers id like to see them
other than that its still a pipe dream
1969 Blue Mini K, 1330cc, Weber 45, polished aluminum roll cage, Race seats, 4 point harness, full rewire incorporating 8 fuses, 6 relays and new headlights :) just needs tyres front shocks and a windscreen til re-register
PostPosted: Sun Mar 01, 2009 12:27 pm
But do you know the physics behind why they work?
PostPosted: Sun Mar 01, 2009 1:26 pm
Milatsmadmini
reducing drag in air dams (also why race cars have front splitters and flat under bodies), venturi effect etc etc lol
http://www.symscape.com/node/373
pretty good picture explaination
PostPosted: Sun Mar 01, 2009 4:41 pm
Just what a mini needs, more rear grip to increase understeer. 8)
 Post subject: one for you Starle boys
PostPosted: Sun Mar 01, 2009 5:11 pm
This thing is meant to be a Toyota Starlet,,, check it out,,, this guys knows what he is doing & isn`t mucking about
http://www.garaget.org/video/1tgwq74hqymh
welll,,, he did know what he was doing until the end of the clip
Edit,,, Oh i forgot to say what i usually say with things like this---> "Ouch"!!!! :-)
PostPosted: Sun Mar 01, 2009 5:52 pm
If only I could turn the clock back to 19 :lol: and make some smarter choices where to spend my money!
Torque steer to me is the deviation of the car from the straight ahead without turning the steering wheel. Just cause a car wants to turn under power and you have to fight it doesn't make it 'torque steer'. My car turns left under power and right with the power off with me holding the wheel in the same position - that's torque steer and its scary. Coming onto the straight at Wakefield say - I point the car roughly where I want to end up, floor it and see what happens...
Also I know the difference between stock, serious power and stupid power - an LSD seems to make little difference but compliance in the suspension bushes certainly does, so do bumps.
All I can say is good luck
Daniel
PostPosted: Sun Mar 01, 2009 8:33 pm
Whoa, massive lose at the end there, and they walked away - unbelieveable!!
