It is currently Wed Jun 25, 2025 11:20 am
 Post subject: Question for Dr Mini
PostPosted: Fri May 21, 2004 9:54 am
when i pulled my head of my mini i found that pistons number 1 and 4 were covered in carbon.
how do i remove this without cauzing any damage.
is there a special way.
thanx JIM
(60 hp @ 5700 RPM) in my old mini.
PostPosted: Fri May 21, 2004 11:25 am
wire wheel on a drill?
PostPosted: Fri May 21, 2004 2:41 pm
I dont think you should be going anywhere near your pistons with a wire brush (its for the head).
I cranked up the two pistons to the top placed a vacume hose next to the one i was cleaning to suck up all loose carbon preventig it from falling bw the piston and the wall and scraped the carbon off slowly with a plastic spatula (i'd use anything as long as its softer than the aluminium so that you dont scratch the pistons). Then polish it all with a metal polish.
PostPosted: Fri May 21, 2004 6:56 pm
Online
I'd leave it there, particularly if the motor's done a lot of mileage.
That ring of carbon around the edge of the piston helps ring sealing- sometimes if you remove it all, the motor will burn some oil for a bit- until there's carbon on it again.. :lol:
PostPosted: Sat May 22, 2004 4:29 am
Havent they been debating for 30 years about the benefits of a carbon ring in reducing oil consumption and still there's no concensus?
PostPosted: Sat May 22, 2004 6:58 am
Online
Maybe- but last time I took it all off the oil use went up for a bit... :wink:
Users browsing this forum: drmini in aust and 77 guests
