It is currently Tue Jun 24, 2025 12:14 am
 Post subject: Starting with a mini
PostPosted: Sat May 08, 2004 12:05 am
I have just bought a 1974 Clubman S with twin carbies and was wondering if anyone has had the problem with the air filter sitting against the firewall and if there are any ways to modify the carbies. The carbies are dell somethings.
TA
Andrew
1974 Leyland 998 Clubman S
Red with White roof.
In need of work (Work being done!)
SWEET!!!!
PostPosted: Sat May 08, 2004 7:03 am
YES. Sounds like you have a Dellorto? on what inlet manifold?
I've had a Dellorto 45DHLA on mine for 10 years and yes, there's not much room there.
1. Use a Lynx Ramflo 440S filter. It is offset upwards for clearance.
Altnough these are really for 38, 40 or 42mm carbs, they will fit on a 45 and work. Make sure the filter's intake holes to the carb are big enough- enlarge if needed.
2. You can remove the carb setup and gently hit the firewall with a BFH (big effing hammer) to create a little clearance.... :wink:
3. If it's a Redline 3005 manifold, you can set it up on a milling machine and remachine the carb flange angle from 12 to 15 degrees. This tilts the carb up a little. Stud holes need to be retapped at a slight angle after doing this.
I have had no problems since doing these mods. 8)
<edit> there was a typo in filter #.
PostPosted: Sun May 09, 2004 8:17 pm
I am not sure of what manifold. I am very new to this mini way of life!! I was thinking that I could get a plate made up with a slight angle on it to lift the filter a bit.
Thanks for the reply. :D :!: :!:
Andrew
SWEET!!!!
PostPosted: Sun May 09, 2004 8:28 pm
Can you email me a pic of what you have, or post a link?
a pic is worth 1000 words... :wink:
PostPosted: Thu May 13, 2004 9:08 pm
Hey Andrew, if you are after any books or videos for inspiration let me know as we have a whole library of stuff. Or just talk to me at next LAN.
PostPosted: Thu May 13, 2004 10:26 pm
LAN? :shock:
PostPosted: Fri May 21, 2004 11:27 am
local area network
PostPosted: Fri May 21, 2004 11:59 am
i know what it is..
just didnt know people on this forum were into that.. cept poeee and prolly tzi :wink:
PostPosted: Fri May 21, 2004 12:26 pm
Nope been a lanner for a long while same with Stillson. And I aint no cs kiddie either..
PostPosted: Fri May 21, 2004 11:06 pm
what u playin then?
...its leaking oil... and thats a good sign!
It lets me know that I havent run out yet. :P -Tzi 4-9-04
