It is currently Wed Jul 23, 2025 9:04 pm
 Post subject: Nylon Unis
PostPosted: Fri Nov 21, 2008 10:21 am
I have found a couple of the plastic type drive couplings that need new uni joints in them. I did a search and found a couple of people said the uni was a Triumph TR6 one, has anyone successfully put new unis in these ? and are they all definately TR6 ones ? dont suppose anyone has the part no. for em ?
PostPosted: Fri Nov 21, 2008 12:55 pm
I've never replaced them but yes they are definitely a TR6 uni inside.
PostPosted: Fri Nov 21, 2008 1:32 pm
Plastic unis are much much better than the rubber donuts. Last for years. :D
Yes I am interested in knowing what type of steel uni is inside as I have a spare set with worn out steel unis.
1969 Cooper "S"
1967 Mini Deluxe
2019 MINI F55 Cooper S
PostPosted: Fri Nov 21, 2008 1:34 pm
There were also some made with steel cones not nylon, I've not seen them for years. :wink:
PostPosted: Fri Nov 21, 2008 1:38 pm
thanks doc
I depise the rubber ones if I find a part no. and price I'll stick it on here
PostPosted: Fri Nov 21, 2008 1:42 pm
p/no for the nylon ones complete was QL5000 I think, but are NLA now. :cry:
Best just fit TR6 unis, don't break the nylon cones getting em off...
<edit> Just spoke to Karcraft, they say the TR6 ones are a GUJ102.
Same as used on Austin 1800.
PostPosted: Fri Nov 21, 2008 4:12 pm
There are actually a few different nylon unis. The QL5000 was made in the UK by Quinton Hazel and they have white nylon cups but there was also a local version made by Hardy Spicer and sold through Repco, these ones have black nylon cups.
The Repco ones were also sold by Leyland Australia. :shock:
Here are a couple that I have picked up on ebay in recent times, one came in Leyland packaging and the other came in Repco packaging...
PostPosted: Fri Nov 21, 2008 4:44 pm
The Mini King
Just a little bit of advise, If you are fitting this type of uni it is most important that the couplings on either side of the uni are in good condition, these can spread a liitle if they have previously been fitted with rubber unis that have worn badly, make sure that each part of the uni fits neatly in the couplings before fitting. :D
PostPosted: Fri Nov 21, 2008 5:03 pm
&&&&&&&& Don`t Over-Tighten Them>>>>>>>>>
i think they`re only meant to go to 8lbs
PostPosted: Fri Nov 21, 2008 6:04 pm
Maybe somebody could arrange to mould some more of these nylon cups up and fit em to TR6 unis, for the benefit of the ausmini populace... :wink:
PostPosted: Fri Nov 21, 2008 6:12 pm
There was someone here that made some. I just can't find his post. :?
PostPosted: Fri Nov 21, 2008 6:14 pm
Doug Lawson on minimania forum made some a while ago. Not sure how they went...
PostPosted: Fri Nov 21, 2008 7:52 pm
look like they'd be relatively easy to machine on a lathe ?
PostPosted: Fri Nov 21, 2008 8:35 pm
They would, except the nylon ones have flats moulded on so they don't turn in the yokes...
I guess you could maybe turn and mill or file them, but moulding is the way to go with big numbers.
Last edited by drmini in aust on Fri Nov 21, 2008 9:48 pm, edited 1 time in total.
PostPosted: Fri Nov 21, 2008 9:44 pm
The current Hardy Spicer number is K5-L4R. These fit the nylon bushes exactly. I bought a number of them about 3 months ago under this number so they are available . Not sure vwhere you are but HS in Campbelfield Vic got mine for me Their phone No is 03 9357 1675
Mk1 Cooper S
Mini K Rally car
Users browsing this forum: timmy201, watsupskip and 102 guests
