13secmini wrote:
are you running a dry or wet car?? if dry then it would pay to get a set of hi-los even for just the fronts, also a set of adjustable shocks for the front, set them fairly firm as you will find you will be scraping your gurads on the smalleest of bumps. rears should be ok if its a dry car as they are set fairly high anyway, what flares are you running with them?
Brad all vans were dry suspension.
I'd fit Hi-Los all round, and adjustable shocks.
Watch out for MIniSport Adjusta Rides (Hi-Lo clones), they take funny size knuckle joints- stock Mini ones are way too loose a fit.
DrMini- 1970 wasaMatic 1360, Mk1S crank, 86.6HP (ATW) =~125 @ crank, 45 Dellorto (38 chokes), RE282 sprint cam, 1.5 rockers, 11.0:1 C/R.
