It is currently Wed Jun 25, 2025 10:53 am
Post new topic Reply to topic  [ 1864 posts ]  Go to page Previous  1 ... 47, 48, 49, 50, 51, 52, 53 ... 125  Next
PostPosted: Wed Oct 15, 2008 8:04 am
Gordo wrote:
Archangel007 wrote:
Making the new EM for the turbs this weekend.
Pics to follow. :D
So how did the new manifold end up Tricky?
Gordo,
Still a work in progress - spent a lot of hours getting the turbs just right, and then jigging it in place. Should have it all finished and welded this weekend! Had a few distractions last weekend as well - Aikido grading for my lad!
Thanks all for your interest, and I should have something substantial to show you this weekend.
Tricky
PostPosted: Mon Oct 20, 2008 10:40 pm
I'm Ernie , Where's Bert ?
any updates tricky?? :P :P :lol:
00' Forester GT
PostPosted: Sat Oct 25, 2008 9:25 am
Hey Lach,
Interruptions, interruptions and more interruptions.
But there is light at the end of the tunnel. The T25/28 flange is done, as is the collector (pics to follow). I held off doing the runners until the new FMIC arrived, which was yesterday. Now I can mate the turbs with the new intercooler, and everything will be just right. Then, I can do the runners.
Unfortunately (for you, fortunate for me), I have tickets to Indy this weekend so there wont be much done this weekend.
I will try and update with pics this Sunday afternoon.
Anyway, off down the Goldie!!
Tricky
PostPosted: Sat Oct 25, 2008 10:19 pm
TAKE PHOTOS OF TOPLESS CHICKS.
and some of the cars :lol: .
PostPosted: Sun Oct 26, 2008 1:36 pm
lucky bugger. :(
been wanting to go for years..
Cheers Dan
PostPosted: Fri Nov 07, 2008 6:40 pm
.... aaaaaaandy ?
Mearcat wrote:
PostPosted: Sat Nov 08, 2008 10:32 am
andrew i think the cat is getting lonely i think it wants some attention.
Cheers Dan
PostPosted: Sat Nov 08, 2008 7:45 pm
He's been hard at at it. Worth the wait I reckon.
PostPosted: Sun Nov 09, 2008 11:32 am
maybe he stayed at indy.. mighta found a nice promo girl and decided he'd move and ditch the cat for another pussy
Mearcat wrote:
PostPosted: Mon Nov 10, 2008 7:58 pm
Hi Everyone, its Tricky!!!
No, didnt stay at Indy Dion, would have loved to though - the women :shock: , the cars 8) , did I mention the women :shock: ?? (Didnt get to take any photos of topless chicks, dammit!!)
However, I have been really busy being social - I have had two weddings in two weekends (friends, not my own). So not a great deal has been done to The Cat, but there has been some. I informed you avid readers last time that we were about to undertake the exhaust manifold (EM) fabrication for the new turbo, and I am glad to say its virtually finished. So, without further adue, here is the process as I see it.
Okay, so the new turbo arrived, but how does it compare to the original CT9? Here is a comparison side-by-side. The KKR280 is slightly smaller than the TD04L, but it is larger than the standard CT9.
And shortly after the arrival of the new turbs, the new FMIC arrived. It is slightly smaller than the first one I bought, and not as high either. But it is slightly thicker. What does this mean, probably not much unless I was racing ten-tenths, but in terms of cooling efficiency it wont be as efficient as the older FMIC as radiator of heat energy. However, it did have the inlets and outlets in the right spot. Here it is mounted in position:
The new FMIC put the inlets and outlets in the proper position for the new turbs etc. As a matter-of-fact, I was really happy with where they ended up.
The inlet:
The outlet:
And here is the new KKR280 in its final position. Its a tight fit in there, but there is about 10mm clearance all around. I realised that I had to rotate the compressor housing to allow the right configuration, and this meant the actuator can mounting bracket will need to be altered.
And here is how the turbo compressor outlet lined up with the FMIC inlet - perfect!!
First step in the building of the EM was to make the flange for the turbine housing - fairly simple really as long as you have a largish holesaw (I already had the head manifold laser cut some time ago):
Then, once the flange is finished, its time to weld some stays to the flange while its on the turbo and in position, and this is what you should end up with. You dont want ANY movement here when you take take the flange off the head. Turbo in position:
Without turbo:
The next part of the puzzle is to manufacture the collector. Ideally, the collector should be between 75mm and 100mm long, and the merge angle should be between 5 and 10 degrees. Mine ended up being 100mm long, and about 8 degrees in angle. They are a real pr!ck to make, and take a lot of time!
Now, tack the collector in position onto the turbine inlet flange, and start building your runners. I had the shape of the final shape of the EM firmly in my mind, so I just started. You may want to search the net and get an idea of the shape you want. My overiding design criteria was simplicity and tuned length, with aesthetics being third. Because the turbo did not sit dead centre to the exhaust ports, but off to one side, I knew the final shape wouldnt be symmetrical anyway. The start of runners 1 and 4:
And this is the final product. Each runner is within 5mm of each other, so design critera number 2 was achieved. Final weight is bang on 6 kilo's, heavier than the cast original EM but it will outflow the original by a factor of about 3!!
Here is the manifold test fit in place. I initially though it looked a bit large and bulbous, but on second thoughts, who gives a toss as long as it flowed!!
So, I wanted to get the new EM into perspective, so I started asembling the car and the other components in the engine bay to see if it would look like a horses ass, and much to my glee, it looked alright. Here it is with the slam panel back in place:
Notice how the EM follows the contours of the front of the car, so as not to foul the grill:
And with the radiator in position:
And with the charge pipes in position. The rear most pipe is the FMIC outlet that goes to the plenum. The front (top-most) pipe is the compressor inlet that goes from the carbon-fibre airbox where the old A-series radiator used to be located.
And then test fit for clearance with the bonnet down - all good!
And a dummy fit of the front spoiler just to see how the spoiler would hide FMIC end-tanks and associated plumbing:
The only thing left to do for the EM is to fully weld it, and then send it off to get ceramic coated inside and out! So, now the next step is to TIG the charge pipes in place, mount the blow-off valve, and plumback it to the compresor inlet - next week perhaps.
Tricky
PostPosted: Mon Nov 10, 2008 9:12 pm
This space for rent
Hi Tricky!!!
Dammit, the suspense is killing me!!
[edit] It was worth the wait, that's a sweeeet looking EM you've built there 8)
So Tricky, what happened with the wheels?
PostPosted: Mon Nov 10, 2008 9:23 pm
Tricky,,, just love your work,,, But the first speed bump is going to be a beauty :-(
PostPosted: Mon Nov 10, 2008 9:37 pm
Wow that's looking good 8) that's a mean looking spoiler with the FMIC sitting their :twisted:
PostPosted: Mon Nov 10, 2008 9:42 pm
Give Ash some flowers Nick .
Looking sweet Tricky 8)
PostPosted: Mon Nov 10, 2008 10:10 pm
WOW! that is lookin very VERY nice indeed..
Love that EM...looks soo nice should look bitchin when its finished! :lol: 8)
nearly there tricky! :D
00' Forester GT
