It is currently Sat Jun 21, 2025 7:22 pm
PostPosted: Thu May 13, 2004 9:20 pm
gday ppls...
now just 2 questions tonight, first is when I pull my fuel tank out to weld on a bigger fuel pipe and fuel return, should I just use water to swish round inside it( when its empty of course) before i start welding, or is there a special thing u can buy for it? i dont wanna get blown up :P
and
cutting the hole in the bulk head, and tips here? thanks guys...
PostPosted: Thu May 13, 2004 9:27 pm
Take the tank somewhere, don't do it yaself. I'm sorry, but the idea of wealding a fuel tank just plain scares me!
PostPosted: Thu May 13, 2004 10:14 pm
:shock: dont try weld petrol tanks yourself, definitley take it to someone. ive heard heaps of horror stories on this one...
PostPosted: Thu May 13, 2004 10:52 pm
I agree with the others re welding it... and I'm a certified welder...!
1. You shouldn't really need a bigger fuel pipe out of the tank. After the electric pump, sure..
2. Easiest way I know to rig a return line is remove fuel gauge sender, weld a pipe into sender, and refit. :wink:
PostPosted: Fri May 14, 2004 1:38 pm
great! thats the fuel tank outa the way! where should I take it?
PostPosted: Tue May 18, 2004 4:47 pm
so with the box, is it as simple as cut and paste? or....
PostPosted: Tue May 18, 2004 5:34 pm
Not..
Serious surgical butchery is involved..
I'd do it like James (kazjim) did on his 998 turbo- put it above the clutch housing. :wink:
PostPosted: Tue May 18, 2004 9:28 pm
Not..
hmm, ill keep that in mind. thanks buddy. whats the best welder for the job?
 Post subject: MIG
PostPosted: Sun May 23, 2004 6:23 am
Borrow a mig for the firewall, its user friendly.
PT tank can be steamed or water filled but remember that petrol floats so weld from the bottom up.
After filling with water, a buddy braised to the outside a larger pipe then drilled it up the centre to open the tank. Seemed to work
PostPosted: Sun May 23, 2004 7:17 am
Putting a turbo box in the firewall is not simple like fitting a Weber box. You have to cut right down thru the crossmember, which seriously weakens the car. Re-shaping it back inside the car is essential. Get it engineered if you do it... :?
I've not done one, but I've seen a couple- and if I was fitting a turbo to my Mini there's no way I would put it there. I'd put it above the clutch, where you can get at the sucker and work on it. 8)
PostPosted: Tue Jun 01, 2004 7:03 pm
I spoke to a friend about welding a fuel tank and he said that you could fill it up with water and weld it. so it wont blow up.
Money is like horsepower, you can never have too much
GTi powered, with a GT25 turbo.
