riddo wrote:
can any of you that have done the conversion tell me if there is any major problems that you encountered when doing the conversion, that i may need to look out for, that is certain things that have to be done that are not obvious at first?
i'm hoping to get most of the bits to do the conversion before i start pulling my mini down, was going to use another subframe and get all of that done before even touching my car.. possibly having the subframe ready for the engine out of the car then installing subframe to car one complete?
i would appreciate anyones ideas on getting started with this.... also has anyone got any spare subframes?
I would highly recommend you remove the oil filter whilst trying to fit the motor. It gets in the way and adds unnecessary complexity when trying to determine the position of the motor. FYI - you can get an oil filter relocation kit for as little as $100.
