It is currently Thu Jun 26, 2025 4:04 am
 Post subject: Hot 998??
PostPosted: Mon Jan 31, 2005 9:17 pm
Im gunna pull my motor out sometime in the next 12 months. Give it a rebuild etc... Wat can i do to it to make it HOT (like as in "racey" not overheating :lol: ). Its apparently had some port work done thats about it. I have all the machining facilities at work. Just after some tips/knowlege on wat can be done.
Cheers Chris
12 Months ?????????????
PostPosted: Mon Jan 31, 2005 9:28 pm
1275 head on it (12g940??), ya gotta pocket the block for valve clearance though. RE13 cam (or a brickworx available one simular, cause you like work there or summit?), corolla rockers, flat top pistons, 45DCOE.
Rocker 998!
PostPosted: Mon Jan 31, 2005 9:32 pm
High lift rockers won't work on a 998, with a high lift cam, and a 45DCOE is really a bit big...
If you must have the induction noise a 40 would do. Pair of HS2 SU's would be a sweeter drive.
A 1098 crank & pistons in it will give more power and torque for street use. No sunstitute for cubic inches.. 8)
Last edited by drmini in aust on Mon Jan 31, 2005 9:34 pm, edited 1 time in total.
PostPosted: Mon Jan 31, 2005 9:34 pm
A 45 with a BIG head and RE13 would be right???
PostPosted: Mon Jan 31, 2005 9:36 pm
Still too big for a 998 roadie I reckon, if you go to 1098 or bigger then yeah.
Of course for racing a 45 is OK.... :lol:
PostPosted: Mon Jan 31, 2005 9:41 pm
Ok... put a 1100 crank in it! hehe
PostPosted: Mon Jan 31, 2005 9:45 pm
Yer Pocket the block..RE13 1098 crank and pistons..maybe +40 +60 940 Head and a 40 Dell and a 3.67 Diff.
Otherwise Turbo or Supercharger $$$$$$$Ching Ching
Don't forget to lighten a number of parts :wink:
PostPosted: Mon Jan 31, 2005 10:06 pm
Got the Cooper S forged 1.5 rockers in a 998 coupled with an 1100(12G202) head and goes a treat. Kept the cam standard though as it would flounder at low revs with anything hotter. DHLA 40mm will give me that sidedrught roar(thanks Makka!!)
Rob
Rob Forsyth
Miniot!!
PostPosted: Mon Jan 31, 2005 10:51 pm
i thought cooper s rockers were round 1.3:1????
68matic: "i havent seen much head in my life "
PostPosted: Tue Feb 01, 2005 5:24 am
They are - however these are the mini spares 1.5 rockers...
Rob Forsyth
Miniot!!
PostPosted: Tue Feb 01, 2005 6:13 am
Not even that- original S rockers are 1.25 if you are lucky. My set of stock S ones tested at 1.24 with an RE-13 cam.
The MiniSpares forged S rockers ARE 1.3.
The MiniSpares 1.5 ones are actually 1.58, according to Keith Calver on MM site. Mine tested at 1.55 with RE-13 cam. :wink:
PostPosted: Tue Feb 01, 2005 7:35 am
Well I built a 998 for a friend recently and it really kicked ass. Here are the specs:
060 overbore
30/70 cam with matched double valve springs
12G202 head. Oversize valves with a bit of cleaning up of the ports
all balanced of course.
1 3/4 inch SU
Extractors, sports exhaust.
on top of a standard Deluxe gearbox with 3.7 diff.
PostPosted: Tue Feb 01, 2005 8:11 am
Yeah a Deluxe 3.76 diff is a good idea with a 998. Goes up hills good then.. :lol:
<edit> 3.76 was used on 997 & 998 Coopers.
PostPosted: Tue Feb 01, 2005 11:33 am
Is a 1 3/4 SU too big for a 998? There's a new HS44 I know for sale locally, but I thought maybe 1 1/2 would be better (I have Mr Vizard's book but haven't read it thoroughly...)
Given it would be for a road car, what sort of other mods with the 1 3/4 would suit it?
PostPosted: Tue Feb 01, 2005 11:54 am
U would mean HIF44. Theres 2 (well that I know of) 1.75" SU's, the HIF44 which has the float underneith, and the HS6 which has the bowl on the side.
They wouldn't be too big for a hot 998. Maybe for a stock one though.
Users browsing this forum: No registered users and 29 guests
