It is currently Wed Jun 25, 2025 6:43 pm
PostPosted: Mon Jan 31, 2005 3:56 am
I have seen a few hi-po minis in mags that have had their discs slotted with 4 slots on each face.
A few questions.....
1. Is this really necessary/beneficial? (Who cares - I just like the sound of it :wink:)
2. What sorta price should I expect for machining 4 slots into each face of my solid 8.4 discs?
3. Would it be cheaper/better to fit a ventilated disc? (The Mg Metro ones fit straight on, yes?)
PostPosted: Mon Jan 31, 2005 6:20 am
Online
If you want 'em, I'd just buy new slotted ones. Yeah they are dearer... :shock:
On a road car with EBC Greenstuff pads, I don't think they are needed. :wink:
PostPosted: Mon Jan 31, 2005 8:13 am
I DWIVE A BIG TWUCK
I DWIVE A BIG TWUCK
they are in the latest car craft catlog round 160 for a pair i think
makka
PostPosted: Mon Jan 31, 2005 9:10 am
I had heard that cross drilled ones are a bit better cause the slotted ones fill up the grooves with pad material and need cleaning out the cross drilled ones are more or less self cleaning.
I think this was on mini mania that I saw it... :?:
Ok eventually found it....
http://www.minimania.com/web/DisplayID/933/SCatagory/BRAKES/DisplayType/Calver%27s%20Corner/CarType//ArticleV.cfm
This said I just went the solid disks, originally intended so there can be no issues about modifications etc :roll:
Roads need more corners
PostPosted: Mon Jan 31, 2005 9:42 am
that's a really interesting article - thanks for posting it fuzzy
PostPosted: Mon Jan 31, 2005 11:47 am
Online
makka
Nope.. they are well over $200/pr now. :cry:
I bought 2 stock ones for Barney & I'll put the Blackstuff pads in. Hey, it's the wife's shopping trolley.. with a servo too it should stop NOW! :lol:
PostPosted: Mon Jan 31, 2005 6:28 pm
well although not a mini my SSS has gti-r breaks up front which are cross drilled and sloted and never had a problem with them. They can pull a little bit due to the grooves but nothing to write home about. I never drove the car with the standard ones on the front but am told the new ones make a hell of a difference. So guess it would be the same thing for a mini. In the end if you have the cash go for it as they look horn.
PostPosted: Tue Feb 01, 2005 8:37 pm
i heard that they can help stop your rotors getting glazed?! true??? if so, it might make more consistant braking and you wouldnt have to rough up the surface with snadpaper anymore...
68matic: "i havent seen much head in my life "
PostPosted: Tue Feb 01, 2005 9:46 pm
Online
I find it's the pads that glaze up, not the rotors.. so I touch 'em up on the linisher if they need it! :P
PostPosted: Tue Feb 01, 2005 9:50 pm
My commodore has DBA Gold cross drilled, vented and slotted discs (I guess you can say my wife is heavy on the pedal and i was worried that she couldn't stop on time :lol: ) anyway I did have some problems, when the pads that I ran (DBA ultimates, great braking power, wore very quick but harsh on the rotors...) it created a slight lip on the discs, I was told it was really difficult to machine, but eventually my cousin (Ultratune Ashfield) did manage to do it.
If you do get cross drilled etc, spend more money on good pads...
Lillee - 1969 Morris Mini K
PostPosted: Tue Feb 01, 2005 9:52 pm
Narp. glazing happened on the pads of poor quality. The cross drilling, slotted and vented discs did nothing to stop that! DBA standards are what I use now on the commodore and they go pretty good. I sometimes forget I am not driving the bombadore and other cars just don't compare :lol:
PostPosted: Tue Feb 01, 2005 10:01 pm
Online
I'm happy with EBC Greenstuffs and stock rotors on the Mini. Kevlar pads don't seem to wear rotors like the metal etc pads did.
On the Ford, I run stock DBA rotors and Bendix std pads. Hey it's only an EA POS... :lol:
PostPosted: Tue Feb 01, 2005 10:11 pm
really? how much would a set of Greenstuffs set me back for my camira setup?
PostPosted: Tue Feb 01, 2005 10:23 pm
Online
I buy from here- search the catalog for yours.
http://www.autospeed.com/shop/category_632/browse.html
:wink:
PostPosted: Wed Feb 02, 2005 3:01 am
I have no intention of cross drilling - from what i've read, mini discs arent really big enough to start drilling aswell, it can weaken em.
Short story...
You know you're doing alot of heavy braking when you spend a day at the race track, then have to drive home with only your HANDbrake!!! This happened with my Mazda at Mallala in 2002.... did about 50 laps, was getting faster and faster.... then noticed my brake pedal started hitting the floor.... Had no idea what the problem was - my mag wheels were actually hot to touch :shock: and the hi-heat paint on my rear drums had totally burnt off...
Drove home (about 2 hours drive if using speed limits, mostly along a highway, then thru the city and suburbs) with ONLY my handbrake to slow me down.
Turns out the brake pads had gotten SO HOT that their compound changed from a solid.... to something that resembled Tinned Milo!!! The contact pad itself crumbled off when I took the pads out of the calipers. :shock:
