It is currently Sat Jun 28, 2025 3:14 am
Post new topic Reply to topic  [ 305 posts ]  Go to page Previous  1 ... 14, 15, 16, 17, 18, 19, 20, 21  Next
PostPosted: Mon Jun 30, 2008 2:26 pm
dont break it
PostPosted: Tue Jul 08, 2008 11:09 pm
ausmini mod
ausmini mod
Ok, finally got the new bits installed.
Yes its a crap picture... better than none I say :)
Thats the crank timing wheel and sensor - no more dizzy, running the megajolt now.
EDIS 4, coilpacks and Megajolt... starts and idles SO much better... need to get laptop connected to setup all the timing.
MANY thanks to Kev (Dr Mini) for the help - couldnt have done it without ya!
Also, Ben as usual ;)
Oh, and thanks again to Kev for letting me leave it there a couple days while I fixed the wiring issues I created :)
One tip!!!! If your car wont start, make sure your fuel pump cut off it turned on! I nearly killed it because it stalled then wouldnt start again... AHHHH! These motor thingy's need fuel do they! :lol:
Oh so tiny :)
Peter
PostPosted: Wed Jul 09, 2008 7:00 am
For those wondering how the Ford ED Falcon trigger wheel is attached, I welded a spacer to it, machined inside the balancer hub for location, then used 2 socket head capscrews into the threaded `puller holes'.
Original idea was to screw it onto the inner hub's flange with M5 screws, until I cut an old balancer up and found it's only 2mm thick there, and, it's only brittle cast iron. :shock:
BTW these things are best attached to the inner hub, as if bolted to the outer, that can sometimes creep around on the rubber insert and muck up the timing.
PostPosted: Wed Jul 09, 2008 12:58 pm
Forum Graffiti
I was going to ask where you got the trigger wheel from... now I don't have too :lol:
Looks great, all I've heard is praise for the MJ ignition. If I was still going A-series I'd run an MJ 8) Does the 'Lite' version have all the features of the big box? It's tiny in comparison :o
PostPosted: Wed Jul 09, 2008 2:41 pm
ausmini mod
ausmini mod
Actually the wheel was off an EL falcon... not ED
Sensor is off the same falcon, coil pack and EDIS4 is off a Mondeo
Good luck getting the Timing wheel off... I spent half the day there... yes I didnt have all the tools needed but boy oh boy.
Ill give you the method :)
Take off grille
Take off Radiator
Take off Air con
Take off belts
Take off top pulley
Undo harmonic balancer nut - size 22 or 24 (cant recall) - Ah! Cant hold the motor...
ok, remove rocker cover
Stick bar in cam timing chain sprocket holes
Get a three prong puller to take off harmonic balancer
Oops, ripped off the balancer from the rubber its mounted to... bugger
Ok, try again now, grabbing the centre of the balancer - yay! Came off
Cool, now I have a balancer and the timing wheel sitting directly behind it...
Oh crap, its pressed on in factory.
Ok, use puller to try to seperate - nope, wont budge
Time for the VBFH stick big flathead screwdriver between timing wheel and balancer, smack, do that on all three 'holes' finally starts to move... keep smacking, pulling with puller, smacking and finally get it off.
Go home and look at this little wheel that cost you $20 and scraped knuckles, half a day and a sunburn
Pete
PostPosted: Wed Jul 09, 2008 7:28 pm
Peter, go get another for a sample, and I'll get a bunch laser cut... out of thicker stuff so no welding needed.:wink:
PostPosted: Wed Jul 09, 2008 8:22 pm
Good to know what model you got it off, why is the coil pack and EDIS4 off a Mondeo and not the EL :?:
PostPosted: Wed Jul 09, 2008 8:43 pm
Mondeo is 4 cylinder and EL is 6
Cheers Pete
PostPosted: Wed Jul 09, 2008 9:28 pm
So why don't you use the wheel and sensor off a mondao then?
PostPosted: Wed Jul 09, 2008 9:41 pm
ausmini mod
ausmini mod
If you think getting it off an EL is hard, you should see the mondeo :) East West Motor if I recall correctly and a nightmare to get to the sensor and timing wheel.
They are all the same thing in essence (off a ford basically) 36-1 toothed wheel (means 35 teeth total and one 'missing') and the VR sensors are all basically the same. Different way they mount, thats about it.
Pete.
PostPosted: Wed Jul 09, 2008 9:42 pm
Have you ever tried to get a crank pulley off a Mondeo (in a wrecking yard with the wrong tools) or any other modern FWD for that matter. PITA... :x
PostPosted: Wed Jul 09, 2008 9:43 pm
ausmini mod
ausmini mod
Yep, no probs mate I will do.
For those interested, you dont have to have a turbo or anything, this is basically timing for any car using the EDIS technology. Expect to pay total for the setup around $400-$500 really... VR sensor, Timing wheel, EDIS4 module, Shielded Wire, and a computer to run it (Eg/ Megajolt, Megasquirt, etc)
Pete.
PostPosted: Mon Oct 13, 2008 10:31 am
ausmini mod
ausmini mod
Ok, so got into her again last week...
Woohoo
Thanks go to Ivan for letting me hijack his workshop and Rob for being very patient with me and the mods :lol:... lots of fiddling and I couldnt have done it without ya.
Out comes the motor
Old diff gooooone :)
In with the bling
Orange diaphram and Race/Rally clutch plate (gee pedal is heavy!)
The new turbo
Back
Exhaust mods
Get in there you b#$%!
Pete
PostPosted: Mon Oct 13, 2008 10:34 am
Milatsmadmini
that new turbo looks sexy pete!!!
im guessing a little easier to spin the wheels now :roll:
:P
PostPosted: Mon Oct 13, 2008 10:56 am
mmm yes looking very nice. i wonder what power figures she willl pull now
Cheers Dan
