It is currently Thu Jun 26, 2025 2:44 am
 Post subject: turbo manifold
PostPosted: Sat Jan 29, 2005 12:14 pm
any heads up on where to get a turbo manifold to suitate the metro t3 over the clutch housing
PostPosted: Sat Jan 29, 2005 1:05 pm
You would have to get something like that custom made, or make it yourself.
PostPosted: Sat Jan 29, 2005 2:44 pm
If you got the do$h, see http://www.miragemotorsport.com/
They do one. 8)
PostPosted: Sat Jan 29, 2005 3:29 pm
They do one. 8)
Hows that for a job! Mod Mini's and work on old F1's in the BOSS series!
PostPosted: Sat Jan 29, 2005 7:04 pm
i have a manifold to suit a garrett t25 (i believe) turbo which mounts it over the clutch cover. I just bought it from brickworx... the only problem i think i am going to have is it was made for a clubby or moke front end, not a round nose, so clearence might be a problem.... I have it setup on another engine now, so if your interested i can send you some pics....
68matic: "i havent seen much head in my life "
PostPosted: Sat Jan 29, 2005 11:14 pm
I have one more left that puts the turbo behind the head.
up high, no firewall mods needed. tight squeeze though.
i had it made for mine and then went factory unit.
cost me a fair bit though
Miniworx Centre 0883741299
Online BMW Mini Shop
PostPosted: Sun Jan 30, 2005 9:53 am
interesting, would it suit the pulsar turbo though? and how would the carb sit then?
How much you looking for this manifold.... I saw a manifold on this sight sometime ago and saved the pic...
I was thinking that I could use a 3-1 set of extractors and loop a new section round to mount the turbo further forward around the engine then have a new dump pipe constructed....
the manifolds that came with the turbo are going to foul on the standard engine steadies....
