Ok, update time.
Turbosmart Vee Port Type 2 BOV fitted and no vacuum leaks
Working great.
Havnt rebuilt the carby yet... might not need to.
Have to dump the oil from the dashpot and put in something thicker... the piston is lifting too quick and leaning her out.
Will go on the rollers for a tune next week... after trying thicker oil.
Might need to retard timing a bit as it growls alot especially coming onto boost - but will sort that on the rollers.
Interior getting there
Dash - Tick
Front door cards - Tick
Rear door cards - Tick
Park brake cover - Tick
Need to do the parcel shelf, roof, etc
Interior light packed it in, not sure whats going on there, will sort soon.
Wheels still not done
Central locking setup is complete and working great (as it was before)
Brakes need adjusting, new rear drums and Cooper S pistons are all bedded in now, but might still have air in the system... unsure, need to bleed and test.
Rear camber brackets still to go on, and then align everything nicely.
Forgot to fit the metal cased fuel filter
better do that asap as the 3psi rated plastic one can explode - Battery + Fuel = disaster
Think I need to soft mount the exhaust on some rubbers, can feel it alot through the body of the car...
Waiting on slides for passenger seat then will fit that properly.
Some of the guages need wiring up (lights in them, etc)
Getting there, now its all the small sh*t to do really.
Pete
